Mach5 Audio...
Username: Skies
Courtenay, British Colu... Canada
Post Number: 493
I was just looking at their subs, and WOW, look at those prices!
After putting in the t/s parameters for a MAW-12 into WinISD, it comes out 2-3 dB higher than a 10" TC-1000, both given same power(750w) and sealed enclosure(.8 cuft).
And for less than half the price!
Are they new?
Reliability?
What kind of SQ can I expect from one of these?
From the 12" Test Session: http://www.realmofexcursion.com/forum/showthread.php?t=14949
Doesn't look too good there though :S
Anyways, any personal experiences with them?
Username: Followyoursole
Los Angeles, CA
Post Number: 81
im about to order 12 maw-15's to replace my fi ssd ported.
Username: Loudon
Post Number: 941
the maw is a beast for the price ....
their company is a non profit ...
good sql sub ...
they are amazing woofers for the price ... to 15s 4.4 cu ft 32z some fill .. ull knock louf
Username: Kaprese
Walstonburg, NC USA
Post Number: 61
I am about to order at the 2 Maw-15's 2 and I will probably use a seal box, but I haven't found a cheap good amp to push them yet I am going for my Kenwood HU tomm., starting all over
Username: Loudon
Post Number: 942
bxi1206d ..
Username: Lil_j
CantonUS
Post Number: 16
I love my MAW-12
Username: Lil_j
CantonUS
Post Number: 18
for two MAW-15's I would do a http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16367
so X2^^^
Username: 420alldaylong
Post Number: 1241
This would be better.
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3942
Username: Skies
Post Number: 496
How does a company function as "non-profit" ?
Jeremiah, how long have you had your MAW-12?
Any complaints to it yet?
Los Angeles, CA
Post Number: 82
im gonna use a hifonics bx1500d.
Username: Lil_j
CantonUS
Post Number: 20
(SkieS) Ive had the sub sins jul 2006.
complaints yes.........NO LOGO WTF?....but that is all. give it a Lil power and BOOOMMMM!
Username: Lil_j
CantonUS
Post Number: 21
what is winlSD????
Username: Skies
Post Number: 501
WinISD is a speaker program of sorts... It's somewhat old, and is outdated as far as new speakers. But you can add your own speakers, just get the t/s parameters from manufacturer website or w/e. You analyze basically the output in dB, you can change box size, ported, sealed, power. Fun tool to use to analyze setups.
Wow, and still no problems since then?
haha nice... how much power are you giving it?
Username: Lil_j
CantonUS
Post Number: 22
on my PG amp (xs250)about 400Wrms and it loved it
but my PG amp died back up amp is a VR3 crap amp
at 8ohms it's like 70Wrms but still loud
the sub has good SQ in a sealed box
.75cu.ft/1cu.ft/2cu.ft but like no SPL but in a
ported box like 2cu.ft@32/33hz it still has good
SQ but ****good SPL so ported FTW
Username: Lil_j
CantonUS
Post Number: 23
O and link to WinlSD?
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 119
If you want to do a US Amps / Mach5 combo, email support@soundsolutionsaudio.com.
