Bronze Member Username: 2000ladeLafayette, IN United States Post Number: 15 Registered: Mar-07 | as the title says. today i took out my Treo SSX's and the big ol box and put my MA Audio 1800xl in my single Treo ssx18 box in the back now. powering it off the old Fosgate 1501bd. well to my suprise i hit a better number sealed on the dash than i did in the same box with the Treo on an mtx 1501d. Vehicle... 2000 Cadillac Escalade box specs... 4 cubes tuned at 34hz amp specs... 1500 at 2 ohm sub specs... dual 4 wired to 2 ohm with the Treo my best sealed on the dash was a 143.2 today i decided to mess around and meter it and well to my suprise i hit a 144.5 with my cheap MA Audio 18 that people said cant be loud. on music i did a 144. so keep in mind the more expensive a woofer is doesnt mean its louder if your goin to be loud on a mic. heres the sub [img]http://i10.photobucket.com/albums/a133/hankveach/DCFC0238Medium-1.jpg[/img] Proof for the non-believers. [img]http://i10.photobucket.com/albums/a133/hankveach/asfasdfasdfasfd.jpg[/img] |
Gold Member Username: Extrmndor3IF U HEAR ME... crazydbs.com Post Number: 4326 Registered: Feb-06 | those ma subs are really cool man i heard them a couple of times and they do get loud and their sq isnt toobad... |
Bronze Member Username: JtownPost Number: 43 Registered: Mar-07 | Speaking of, someone mentioned to me earlier in a diff thread, saying that Jls cant get loud. I have 3 12" W0 (discontinued). They are at 125rms each. I ran em off a 500w fosgate in a sealed box. what did I hit? 145.6 |
Silver Member Username: Adam_s15 TC9 Hybrid, RE MT Softparts Post Number: 950 Registered: Aug-04 | Justin was that on a TL?? |
Silver Member Username: BasssquaredPost Number: 287 Registered: Nov-06 | richard dont forget to charge your laptop looks like its low lol |
Gold Member Username: Tremor1127Fi Car Audio has got m... Post Number: 1259 Registered: Aug-06 | quit saying loud and spl in the same sentence people... |
Gold Member Username: Tremor1127Fi Car Audio has got m... Post Number: 1260 Registered: Aug-06 | quit saying loud and spl in the same sentence, people... |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 2337 Registered: Jan-06 | spl=sound pressure >LOUDness< duh! |
Silver Member Username: MmaudioconceptsMurray, KY Post Number: 112 Registered: Jan-07 | actually loudness and sound pressure level are two different things....if spl had anything to do with being loud,,,then tweeters would hit high numbers spl comps |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 2341 Registered: Jan-06 | WOOPS My bad, i forgot it was Sound Pressure Level, not Loudness BTW why is spl measured in decibels if its not a measure of loudness? |
Silver Member Username: Rosrock2000AA Assassins, MI USA Post Number: 395 Registered: Dec-06 | when u see what what u can hit you turn off your co's and other speakers right? just play subs? |
Silver Member Username: Waterboy2289Martinez, Georgia 2 18 SX w/ ... Post Number: 179 Registered: Jan-06 | I'm suprised the MA was louder. It shouldn't be. Sounds like the SSX needs a better box, because it is by far the superior woofer. Also, the Fosgate amp probably puts out more power than the MTX. |
Gold Member Username: Denali_on_22sHit you in the chest m... Post Number: 1781 Registered: Feb-06 | Yeah, the Fosgate prolly puts out around 2000 RMS... Still good nummbers from that MA though. |
Bronze Member Username: JtownPost Number: 45 Registered: Mar-07 | What is a TL? I got it metered at a local car audio shop, if that answers your question...lol |
Silver Member Username: SheriffPost Number: 257 Registered: Jan-07 | No that doesn't answer the question Justin. Glad to hear the MA hitting high numbers. I knew they were up there somewhere. My sister's boyfriend hit 144 with an MA1500XL 15", which is what I now have. I will get it metered soon hopefully. |
Bronze Member Username: JtownPost Number: 46 Registered: Mar-07 | "Justin was that on a TL??" ^So then what was he asking?^ |
Silver Member Username: SheriffPost Number: 260 Registered: Jan-07 | Yes, that is what he asked. Did you meter it on a TermLab? |
Gold Member Username: James1115Use a simple... Post Number: 9782 Registered: Dec-04 | there are a few different ways to meter it also Justin. You can run it with your doors open, windows down, doors shut and windows shut, on the dash, on the kick panel, on the port, there are many ways that effect the #'s you will hit. I assume you tested yours outlaw to get those #'s with those subs. |
Silver Member Username: MmaudioconceptsMurray, KY Post Number: 114 Registered: Jan-07 | ATTN Wolfman http://realmofexcursion.com/videos/Various/termlab.1.wmv |
Bronze Member Username: 2000ladeLafayette, IN United States Post Number: 18 Registered: Mar-07 | yes that was sealed on the dash DB Drag style. i managed to mic a 144.9 today sealed on the dash messing with box placement. i wouldnt post a score if it wasnt sealed on the dash because any other doesnt mean crap to me. |
Bronze Member Username: JtownPost Number: 47 Registered: Mar-07 | I sat in my car with the windows up and doors shut, the guy that worked at the place sat in the passenger seat and held the mic on his lap at first, and then moved the mic toward his feet, and then held it over the dash. I hit 'those #'s' when it was sitting in his lap. I didn't ask what kinda meter it was. And what is getting it tested outlaw? Thanks. |
