Tire size for rims
Username: Redliner
Wilmington, Ma
Post Number: 3710
alright guys i wont even pretend like i know anything about this lol.
okay i am gonna get these rims
http://www.1010tires.com/wheel.asp?wheelbrand=Konig&wheelmodel=Hotswap+%2D+Black
now how do i know what tire size i need the rim is 18" X 8" 5/114.3 40 so how do i know
http://www.1010tires.com/tire.asp?tirebrand=Toyo&tiremodel=Proxes+T1R
these are the type of tires i want just not sure what size to get
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4080
depends on what car you have.... what car DO you have? lol
Username: Redliner
Wilmington, Ma
Post Number: 3711
2000 eclipse
Username: Redliner
Wilmington, Ma
Post Number: 3713
why should it depend on the car i have if i already know the rim cause doesnt the tire just go on the rim lol i mean i know the right bolt pattern and offset and what not for the rim so shouldnt u just pick a tire to on the rim now? i dont get it sorry if i sound stupid ive just never done this b4 lol oh and do u guys like those rims?
Username: Th3pwn3r
Post Number:...
Post Number: 1632
If your tire is too wide/fat it will rub the wheel well same if you get too tall of a tire.The same rim will may also fit fine with some low profile tires.Catch my drift?
Username: Frkkevin
Post Number: 3413
205 45R 18 .... this will only make your speedo .7 mph faster
Username: Frkkevin
Post Number: 3415
if you want wider.. go with a 225 40R 18.. its only .3 mph .. but very little sidewall so watch them pot holes!
Username: Van_man
Boston South, MA
Post Number: 2314
http://www.miata.net/garage/tirecalc.html
Username: The_image_dynamic
San Diego
Post Number: 781
http://www.tirerack.com/
Username: Freezeman_7
Lindsay, Oklahoma U.S.A
Post Number: 838
nice. but i thought the rims through ur speedo off. actually im positive the rims are what throus it off. i mean it can be re-calibrated. cause mine used to be bout 7mph off. cause my truck was set for factory 17' then i put 22's on it. f*cked it up. if it rubs the wheel well sides, jus cut some of it off. simple fix.
Need to Register?
Forgot Password?
Enable HTML code in message
