Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 153 Registered: Sep-05 | sup guys. i have gone through quit a few different subs in the last couple months. 10's and 12's. but with the limited space, i hate having to move my seat forward just to fit the d@mn box in there. and i already put a box as my center console, but i really like the stock look. so here is my plan. i want to do a dual 8" setup. i have been looking at the j 8w3v2 dual 4 ohm subs. and to power it probably a kicker zx750.1. or go with a pair of the soundsplinter rl-i8's powered by a hifonics bxi 1206d. both setups would be in their recomended ported enclosures. which do you guys would sound better or maybe get a little louder? i have never heard the soundsplinter subs. but i have heard alot of jl's. but i think the rl-i8's will pound a little harder. let me know what you guys think. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 1649 Registered: Jul-06 | I think you need quite a few 8''s to get fairly loud so...I know I wouldn't be satisfied with two. |
Gold Member Username: Arande2Extreme SQ FTW Post Number: 2171 Registered: Dec-06 | 8s can get REALLY loud if you give them a lightning strike. It really shows how big lightning really is doesn't it? It's a few feet in diameter it looks like. |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 155 Registered: Sep-05 | i dont want the subs to get hella loud. this is going to be a sq setup. but which setup would sound better? anyone heard some jl 8" subs? or any other sub manufacturer? |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 2359 Registered: Jan-06 | RE8's!!! http://s21.photobucket.com/albums/b258/MDW1966/?action=view¤t=5370880e.pbr |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 638 Registered: Dec-06 | I have heard that those SS are awesome. Haven't heard any personally tho I think you would be happy with either setup, or even the RE8s. Personally tho I would go with the Digital Designs 1508. Those look sick and they would be cheaper than the SS. Me likey |
Silver Member Username: Liqdfire3Lee high acres, Florida Post Number: 156 Registered: Sep-05 | hell yeah. i didnt even know digital designs made a 8 inch sub. i will definitely look into them. thanks ben. |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 641 Registered: Dec-06 | No problem man. I would highly recommend doing those DDs. |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 468 Registered: Oct-06 | http://realmofexcursion.com/videos/SoundSplinter/rli8.1.wmv |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 2370 Registered: Jan-06 | http://www.realmofexcursion.com/videos/REAudio/re8.13.wmv |
Gold Member Username: IlluminatorUSA Post Number: 4920 Registered: Apr-05 | All good suggestions The DD's and JL's would really be nice, though.
Lightning itself is about as thin as a pencil, I think you're talking about the luminous corona (made of hot ionized gases) which envelops the lightning channel. |
