Resonant Engineering XX???
Username: Mgbcs
Lincoln, Nebraska
Post Number: 591
A buddy of mine has a Resonant Engineering sub that he says is a XX? Did they make a XX before the XXX or is he mistaken? He bought that based on the person claiming a XX, so I don't know.
Username: Logan__tille
Http://com4.runboard.c...
Post Number: 6712
What?? Is it an RE?
Username: Frkkevin
Post Number: 3407
take pics :-)
Username: Skies
Courtenay, British Colu... Canada
Post Number: 447
No hes probably just mistaken.
Before the XXX was the Sexxx I believe.
I don't think there was anything before that though.
Username: Sheriff
Post Number: 195
Ya, I've never heard of an XX.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 595
I am in Nebraska and he is in Minnesota. I can try to get him to send pics, but not sure he has a digital.
And yes Logan, it is certainly a RE, but I am not sure what kind. I think it is like 3 years old and handles about 1500 watts. (Don't think that helps tho)
Username: Southernrebel
Post Number: 4750
Its prolly a pre-XBL XXX.
Bet it has a b()()b cone :-)
btw...why the hell cant we say b()()b?
Username: Mgbcs
Lincoln, Nebraska
Post Number: 596
hey Canaan, what do you mean a pre-XBL? Is that a technology they have now I assume?
Post Number: 4751
No...RE uses split-coil in the XXX's now. They used to use XBL^2 in the 05-06 XXX's. (This is a motor topography created by Adire Audio. RE licensed the rights to use it.)
The pre-XBL^2 XXX was an overhung motor, if i remember correctly.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 597
Alright. I will try to get him to send pics, cuz I am more curious than he is I think. It's very loud (I haven't heard much but it's the one of the best I've seen)
Username: Visitor01
Post Number: 46
seXXX came out AFTER the xxx... all it is is an se with XXX soft parts. Sounds like what he has... order re subs came out- HC was the original, XXX came out (with the b()()b cone) SE came out, then came SEXXX (although it was never a production sub, had to call and specifically ask for it) then the SX came out, and HC line was dropped, then i believe it was the re series, then came MX,new XXX, SR, etc...
Username: Visitor01
Post Number: 47
btw- their was no "pre-xbl xxx"... that would be an hc.
Post Number: 6720
lol
Username: Mgbcs
Lincoln, Nebraska
Post Number: 635
alright here'a a pic of it. i guess it's 1000wrms so does anyone know?
Username: Frkkevin
Post Number: 3412
hmmm.. thats got SX all over it.. makes me wonder if it was reconed and just used SX softparts.. or if its actually an SX :-)
Username: Mgbcs
Lincoln, Nebraska
Post Number: 637
It very well may be. Anyone else?
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 951
I am also thinking SX. It was the first thing that popped into my head after seeing that pic.
Need to Register?
Forgot Password?
Enable HTML code in message
