How tune my amp
Username: Splsq
Chesterland , Ohio USA
Post Number: 93
ok i have a couple questions how do i tune my amp so the bass is really loud. this is the amphttp://images.google.com/imgres?imgurl=http://www.cardiscountstereos.com/Images_ For_Catalog/ZXI6006.jpg&imgrefurl=http://www.cardiscountstereos.com/manufacturer s.asp%3Fmanufacturer%3DHifonics&h=180&w=300&sz=8&hl=en&start=10&tbnid=QeNY7VVX5U KqGM:&tbnh=70&tbnw=116&prev=/images%3Fq%3DHifonics%2BZeus%26gbv%3D2%26svnum%3D10 %26hl%3Den
so like what do i turn up and down on the amp.
Username: Volfenhagking1600
I WILL be 15 Wangin
Post Number: 456
http://www.icixsound.com/vb/showthread.php?s=2fe443e624f9655155159e36550808f6&t= 27819
Username: Splsq
Post Number: 94
ok yea thats wierd but what i dont get is i have my new amp hooked up a hifonics amp and the people at cc tuned so it sounds nice but what i dont get is my old amp made the subs louder and it was a Sony Xplod amp and best buy tuned so is it weird that the hifonics sounds weaker then the sony?
I WILL be 15 Wangin
Post Number: 457
whats the rms on both amps?
I WILL be 15 Wangin
Post Number: 458
also, what are you pushin with that amp (subs)
Username: Splsq
Post Number: 95
well they sony only give lile 150 watts RMS and the hifonics gives like 400 and the subs are 2 12inch Kicker L5s
15 SSD Wangin, Shawano, Wis... USA
Post Number: 464
the sub is dual 4 ohm right?
how were the subs wired with the hifonics?
and how are they wired with the sony?
Same way?
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 931
Voice coil configurations?? They could be wired wrong.
Username: Splsq
Post Number: 96
there 2ohms subs and there not wired wrong because they work and hit nice and hard but its just wierd that the sony made them hit harder then the hifonics.
Username: Adam_s
Post Number: 935
How is the gain set??
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1228
These are the specs on your amp,
150 Watts RMS x 2 @ 4 Ohms
300 Watts RMS x 2 @ 2 Ohms
600 Watts RMS x 1 @ 4 Ohms
You have dual 2 ohm subs. The only wiring option you have with that amp is to run each sub to its own channel at a 4 ohm load. And as you can see both subs are seeing about 150 watts rms. Given efficiency and hifonics is a little overrated, I would say you are seeing about 100wrms each.
Username: Splsq
Post Number: 97
no way im not giving them only 100 watts cause its not like there not moving but i mean the subs are really loud i mean REALLY LOUD!!!! i just want to no how to change everything.
Username: Splsq
Post Number: 98
and how do i bridge the amp or can i
Username: Jonesp
Post Number: 202
dude shut up
its simple that you lying about something, have no clue what your talking about or you have super hearing. there is no way 2 l5 with 200 rms any kind of way loud. it probally sound like someone is kicking the side of your car
Username: Adam_s
Post Number: 941
Yeah this is ridiculous. Is the bass too loud or too quiet. I have no idea what you are talking about anymore.
Username: Splsq
Post Number: 99
its not loud enough but never mind i got everything fixed and set up nice. took it up to Circuit City and they tuned it.
thanks for ur help.
Post Number: 472
good ol' circuit city...
Username: Adam_s
Post Number: 944
^^Always count on the doing a GREAT job.
Username: Th3pwn3r
Post Number:...
Post Number: 1605
They probably maxed out his gain :-( He's also probably wondering what that funny smell is.
Username: Splsq
Post Number: 100
they do a great job and like them when they install stuff but man do there subs and amps cost alot of money.
Username: Adam_s
Post Number: 946
They don't always do a great job. I have been there many times and have had conversations with the people there and they have no idea about how to wire subs differently and ABSOLUTELY nothing about ported boxes. JMO but I would rather learn it and do it myself.
Post Number: 473
next time u go there carl ask them what gain does on your amp...
Username: Splsq
Post Number: 101
ok i will. I think im going to get another hifonics amp to power each sub with its own amp.
Need to Register?
Forgot Password?
Enable HTML code in message
