New member Username: Bigeddie27
Orillia,
Ontario
Post Number: 4 Registered: Dec-05
Posted on How do you clone one viewsat ultra to another viewsat ultra THANKS |
Silver Member Username: Brucester
Post Number: 405 Registered: Jul-06
Posted on Viewsat To Viewsat Clone How 2 -------------------------------------------------------------------------------- Clone A ViewSat * STB --> STB Data Transfer between VS boxes For use in cloning one ViewSat to another. a. Connect the "Master" ViewSat to your TV; Power switch "ON" b. Connect the "Clone" to the wall power; switch Power "OFF" c. Connect the "Master" and "Clone" ViewSats using a NULL MODEM cable d. MENU--INSTALLATION--RECEIVER UPGRADE--ALL INFORMATION e. "OK" and the "MASTER" ViewSat sets up to send data tothe Clone" ViewSat f. Turn the "Clone" ViewSat's power switch to "ON" and the transfer begins NOTE: AFter the transfer is completed, the "Clone" ViewSat needs up to 1 minute to process the transferred data. Watch the Front Panel on the "Clone" ViewSat. "inst" will be displayed for ~ 15 seconds "DONE" will be displayed for ~ 10 seconds REBOOT will occur automatically without user intervention " on " will be displayed during reboot "0 0 0 0" will show when the "Clone" has finished--no more than 1 minute after data transfer You may now Power "OFF" the "Clone" ViewSat, disconnect the NULL MODEM cable and go use your new Clone ViewSat hope this helps some out .. this works well. HAPPY TESTING __________________ went and got this info from dssrookie*com chang the *to a dot . |
Orillia,
Ontario
Post Number: 5 Registered: Dec-05
Posted on thanks: Bruce1 |
Post Number: 410 Registered: Jul-06
Posted on your welcome bigeddie27 glad i can help |
