$2,000 to play - help me build a system??
Username: Aceshigh
Hey guys, I have been on here for a few years just lurking from time to time mostly in 2005 when I was researching for my own home theater system purchase. In 2005 I bought myself a Harmon Kardon AVR-635 and Klipsch Reference RF-35, RC-35, RS-35 and an RW-12 sub. I love my system in truth but it costed a huge chunk of change in comparison to this budget.
So this is for my buddy who is an Army Sergeant over in Afghanistan and he asked me to help him build as good of a system as we can for $2,000 , not I personally have read ALOT about SVS Subwoofers being the best out there, and was thinking it would be the best option for his subwoofer.
So please chime in on what you think would be a great combination in that pricerange. I'm sure if he needs to go a LITTLE over that budget he would, but lets try to keep it in that pricerange. No bookshelf speakers preferably. I think he wants to really see what he's buying standing tall like I did.
Thanks ahead of time guys. BTW, he has a 42inch plasma with HDMI so I'm sure that will be necessary.
Username: Arande2
Extreme SQ FTW
Post Number: 1838
So you mean $2000 for the whole system..
My second choice would be SVS for that price range. First would be building an IB subwoofer for about $6-700 with a 1500w amp and 2 Fi 15" Q's being driven. Then I'd probably buy a Paradigm Center, surrounds, and mains for ~$600 I'd buy a Pioneer Elite HDMI out player for $300 and with what's left I'd get the $650 Pioneer Elite receiver. Now this is my personal choice on that budget.. opinions may differ. The subs would get to maybe 120-130dB around 20hz and maximum output would drop below that, but would be flat to ~10hz. The speakers would be able to keep up and the Dvd player and Receiver are no lie, I've seen and heard the Price/Performance ratio.
Username: Aceshigh
$2000 for
Receiver
Speakers
Subwoofer
Username: Project6
Post Number: 13354
For that budget I would recommend these:
Pioneer VSX-1016 $450
Athena Speakers
ASF-2.2 $400/pair for the front
ASC-1.2 $150 for the center
ASR-1.2 $240/pair for the rears
HSU sub VTF-2 $400
Nice wiggle room for other stuff like cabling, etc.
Username: Chovongai
Berny,
I'm newbie so please forgive my ignorance.
Can I use a 7.1 receiver having just 5 speakers like the system you suu
Username: Project6
Post Number: 13564
Yes, you can use a 7.1 receiver even with only 5.1 speaker system.
Username: Arande2
Extreme SQ FTW
Post Number: 2032
I think it also gives more power supply headroom so you have more power at hand, am I right?
Username: Chovongai
My guess is that I should forget the two back surrounds speakers, right ?
And if so, will I miss the intended sound effects, or will the end results are insignificant ?
Thanks,
DT
Username: Project6
Post Number: 13565
Yes, you should forget the back surrounds and no you will not miss the intended sound effects. The end results are not significant.
Username: Alright_boy
Post Number: 84
I generally agree with Berny on the back surround issue. However, the loss of information may or may not be considered significant depending on the material and listener. I would say the loss is most noticeable on high impact/action movies with a lot of special effects, much less so on drama or low effects material. I've done it both ways and my current configuration does not have the back surrounds. I can't honestly say that I really miss them.
Username: Chovongai
Thanks everybody for your inputs!
DT
