Bronze Member Username: Mightyfish
United states
Post Number: 28 Registered: Jun-06
Posted on What is the easiest, cheapest, and least messy way to seal of a trunk? |
Silver Member Username: Killswitchjd
Post Number: 296 Registered: Apr-06
Posted on you mean glue it permanently down or what? seal? my trunk is already sealed. you want sound deadening or are you looking for a tighter fit or what |
Silver Member Username: Dakangofkrunk16
Earth
Post Number: 381 Registered: Mar-07
Posted on sound deadning would be to use edead |
