Bronze Member Username: MercsableKalamazoo, MI USA Post Number: 59 Registered: Apr-06 | I am wondering if this is the correct wiring. I ask because I am not directly connecting each sub to the amp..the one sub is indirectly wired. Surprisingly, this is not an actual photo of the subs. I had to draw them by hand. |
Bronze Member Username: Rob1083Post Number: 100 Registered: Mar-07 | http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22 |
Gold Member Username: Van_manBoston South, MA Post Number: 2266 Registered: Mar-06 | yes |
Bronze Member Username: MercsableKalamazoo, MI USA Post Number: 60 Registered: Apr-06 | Well then I guess I dont understand. I had 2 SS Rl-P 12s 750wrms a piece 2ohmDVC wired at 2 ohms. My infinity amp puts out 1300wrms at 2 ohms. Then I decided to wire one of the subs by itself and it put out a 4ohm load which my amp puts out 854 at 4ohms. My single sub alone sounded better in both SPL and SQ than when there were 2. WTF..?? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1072 Registered: Jul-06 | Yes that would make a 2 ohm load. But make the double connection at the amp, not at one set of terminals on the box. The way you have it, twice as much current has to flow through the wires between the amp and the double connection. The wire may not be heavy enough gauge. |
Bronze Member Username: MercsableKalamazoo, MI USA Post Number: 61 Registered: Apr-06 | So that would cause 1 to sound better than 2? |
Gold Member Username: Matt12490California USA Post Number: 2018 Registered: May-05 | No it wouldn't. Can you draw another diagram like that and show us how you wired your 1 sub? |
Bronze Member Username: MercsableKalamazoo, MI USA Post Number: 70 Registered: Apr-06 | just imagine pulling out the wires from the terminal that has the double connection |
