Silver Member Username: Dakangofkrunk16Post Number: 119 Registered: Mar-07 | Ok im gettin a chevy caprice and i was wondering what would be betta a 18btl or 2 15 btl or if i could 2 18 btls or 3 12 btl and rite now i have a jl 1000/1 so that will be powering it untill i sell that and i was wondering what would be the best amp nto to expensive and if anyone nows the maxx watts of the subs i no the rms is 2000 thanx n advance |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11451 Registered: Oct-05 | i am giving 5000wrms to my 2 15" btl's right now and they take it fine. i am about to upgrade that to 8000wrms. 2000wrms won't even do anything to those subs. if you get those subs you better be ready to give them at least 2500wrms each. |
Silver Member Username: Dakangofkrunk16Post Number: 120 Registered: Mar-07 | whats a good amp 4 that ive been lookin and couldnt find except the planet audio Planet Audio VX2200D and could i possibly fit 2 18's in a caprice |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11453 Registered: Oct-05 | that amp for 2 btl's? not enough. also i wouldn't put 2 18s in your trunk unless you can fit a 10 cuft net box. go with 2 15s or 3 12s. also at least 2 of those amps you mentioned. |
Silver Member Username: Dakangofkrunk16Post Number: 121 Registered: Mar-07 | but how would one 18 and that amp sound altho im pretty sure the 2 15's would thump much louder and do u no the maxs watts |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11454 Registered: Oct-05 | if you don't power it properly, the subs won't be efficient. if you must go with 2 18s, then i suggest you get 2 18 BL's for that amp. also if you get the btl's, i wouldn't even bother hooking it up to that jl amp. |
Silver Member Username: Dakangofkrunk16Post Number: 123 Registered: Mar-07 | also all the options what does the universal one mean and what would be betta spl or daily i will be usin it daily but i want it to have serious spl sry 4 askin all these questions im a noob when it comes to the fi subwoofers but not car audio just these subs |
Silver Member Username: Dakangofkrunk16Post Number: 124 Registered: Mar-07 | aight so ima go with 2 15's btl's and 2 of those planet audio amps yea i no ima have to sell the jl 1000/1 to buy what i need thanx 4 the help |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11455 Registered: Oct-05 | np. make sure you have at least an extra battery in the trunk and a ho alt. btw that amp does 2000wrms right? |
Silver Member Username: Dakangofkrunk16Post Number: 125 Registered: Mar-07 | 2200 BUT I CAN'T FIND IT ON A GOOD PRICE DO U HAVE AN AMP IN MIND AROUND 500 DOLLAZ OR SO |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11458 Registered: Oct-05 | massive audio p3000. you can get it from low-hz for around that price. it does 3000wrms and its underrated. |
Silver Member Username: Dakangofkrunk16Post Number: 127 Registered: Mar-07 | onyl the sundown amps are showin up unda amps there |
Silver Member Username: Dakangofkrunk16Post Number: 128 Registered: Mar-07 | http://cgi.ebay.com/2000-Watt-RMS-Illuminated-Brutus-Amp-w-Variable-24dB-S_W0QQi temZ190089010272QQcategoryZ88433QQssPageNameZWDVWQQrdZ1QQcmdZViewItemwould that be good if not let me get another amp that would be good im not tryin to be anoyin but i wanna get the most outta these subs wit out them blowin |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1068 Registered: Jul-06 | That's not enough power, for 2 BTLs you will need at least 4000 watts. 2000 watts would be good for one. |
Silver Member Username: Rob1083Post Number: 101 Registered: Mar-07 | http://cgi.ebay.com/MASSIVE-AUDIO-P3000-1-CAR-CLASS-D-SUBWOOFER-AMPLIFIER_W0QQit emZ140099563177QQcategoryZ18797QQcmdZViewItem still not 4000 though. i don't know where you'd get 4000 rms for around $500, but i'd like to find out |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11471 Registered: Oct-05 | i was telling him he needs 2 of those massive audio amps for 2 btl's. i was under the impression that he is willing to spend $500 on each amp. if you are not going to have too much power, i would suggest you get the BL's. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1075 Registered: Jul-06 | I almost got a blown Powerbass 3000 for $80 that I could have fixed, but one person beat me to it. http://www.caraudio.com/forum/showthread.php?t=222928 |
Silver Member Username: Dakangofkrunk16Post Number: 129 Registered: Mar-07 | o no mybad i ment 500 for each amp and i would get 2 of those amps |
Silver Member Username: Dakangofkrunk16Post Number: 130 Registered: Mar-07 | http://www.sonicelectronix.com/item_6523_Hifonics+BXi+2006D.html http://www.sonicelectronix.com/item_4238_Hifonics+XX-Hercules.html i would be gattn 2 of both which eva amp i would grt |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11472 Registered: Oct-05 | over rated. that thing won't be putting out 2000wrms. don't be cheap on amps man. spend around 700 and get something good. |
Silver Member Username: Dakangofkrunk16Post Number: 131 Registered: Mar-07 | aight ive heard they dont put out what they say just list all the amps i should get dont care about price and ill b gettin 2 |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 11473 Registered: Oct-05 | orion 2500d kicker zx2500.1 massive audio p3000.3 1 memphis 4kw some of the amps off the top of my head for now. |
Silver Member Username: Dakangofkrunk16Post Number: 133 Registered: Mar-07 | ima go with the memphis 4kw cause that is the cheapest one cause i will only need 1 and it looks really good thanxs |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11032 Registered: Jul-05 | he could also buy the regular 15 btl & not the modified 1 ........ |
Silver Member Username: Dakangofkrunk16Post Number: 139 Registered: Mar-07 | no im goin with the modified one dual 2 and have it in parallel to make a 2ohm load so it will get 4000watts rms |
