ok.. so my sub has been hitting backwards for a while now and I just got a new amp so I thought maybe it would hit forward but nope. I tried changing the positive and negative wires, switching phase and nothing. Right now I have the positive in the negative and the negative in the positive since it seems to work better that way. If I put positive in positive and negative in negative it still goes backwards just not as much, kinda halfway. Any ideas???
You can see it hitting backwards, also it sounds like it is hitting itself when I turn the volume up. Its a kicker cvr 15' i think something is messed up inside it? how do I fix this...
ok I was going to try this but I wasnt sure how to go about it. Its a dvc 4 ohm how do I do that just leave it wired as it is and put the wires coming off that are going to the amp onto the pos and neg of the battery?
I guess I'm going to have to... Its been like this for a while I Thought maybe with a new amp it would go outward but still nothing... It doesnt make any sense that it would go outward on a D battery but not from an amp.
its the kenwood kac9102d, it does have a phase switch but that doesnt change anything already tried it. My sub was doing this with my old amp too which was a bazooka el1500. It used to go outwards though which is weird. Did my terminals lose their polarity or somethign on my sub?
