Strange...
Username: Mgbcs
Lincoln, Nebraska
Post Number: 565
OK...I am back in Nebraska and was having trouble with my bro's car in Minnesota before I left. Anyway, he tore it apart and found that there was no power from the battery to the amp. Everything LOOKS fine in the run, but the power is good before the fuse and is not running thru it. The fuse does not look blown, but can it still be? Or is it more likely a bad fuse holder? Thanks, I appreciate it!
Username: Kaos15th
Post Number: 433
is it the glass fuse? if it is change it somethimes they look good but they're really blown. Happened to me a few times
Username: Mgbcs
Lincoln, Nebraska
Post Number: 566
Yeah it's one of those glass ones with the fuse thru the middle. I'll tell him to just switch it out. Thanks
