Silver Member Username: PaogrAthensGreece Post Number: 102 Registered: Dec-05 | Should i built this box, 2.5cf@35Hz: http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=15&Dia=7&Xmax=12&Vd= 0.1&NumW=1&Vb=2.5&Fb=35&Qts=&Vas=&Fs=&CE=0 or this box, 3cf@35Hz: http://www.subwoofertools.com/forum/ported-box.asp?Ew=33&Eh=15&Dia=7&Xmax=12&Vd= 0.1&NumW=1&Vb=3&Fb=35&Qts=&Vas=&Fs=&CE=0 the bigger the better? |
Gold Member Username: Van_manBoston South, MA Post Number: 2258 Registered: Mar-06 | Niether.. You want 3.25 cf tuned to 32 http://www.kicker.com/06/tech-support/manuals/manuals/02SL7TechManualV2_0.pdf but if you gonna buy one, get the 3 |
Silver Member Username: PaogrAthensGreece Post Number: 103 Registered: Dec-05 | No I'm not gonna buy one, it's for a friend and we will built it. Thanks but 32Hz isn't low for the 12" L7? It has 34Hz fs, that's why i said 35hz... |
Gold Member Username: Van_manBoston South, MA Post Number: 2262 Registered: Mar-06 | 35 would be good also. I had mine at 30 and it was good. If you do the math on the kicker web site, you can figure out what the tuning is on the spec box. Just plug thier numbers into the box calc. |
