Car audio in home hook up
Username: Quirky
SA, Texas
Post Number: 70
my friend has a 15" sub and a 1000.1 kicker amplifier. he took it out of his car because it is currently in the shop and was wondering if he could hook it up in his house by directly connecting it to a 12v motorcycle battery. is this possible to work or am i just trying to fry something here?
Username: Nd4spd18
Southeast PA
Post Number: 1008
In order to do that you would need a large 12 volt regulated DC power supply (they are expensive).
DO NOT use that battery indoors unless it is a sealed battery. Regular batteries produce hydrogen gas.
Username: Nd4spd18
Southeast PA
Post Number: 1009
didn't bump
Username: Quirky
SA, Texas
Post Number: 71
so the only thing i should be worried about is the battery exploding, but my amp and sub should be ok? or is this all just one bad idea looking to blow up my house haha?
Username: Nd4spd18
Southeast PA
Post Number: 1013
A non-sealed battery can't be used indoors. That's all there is to it.
Username: Quirky
SA, Texas
Post Number: 72
what if i open a window? =)
A pic is worth 1000 words
Post Number: 4852
Motorcycle battery? That would last about 1/2 a second for power supply. Opening a window won't help you if you short the bat out and it explodes. Just don't do it.
Username: Quirky
SA, Texas
Post Number: 73
haha ok ok =( it would be cool to get it to work though. alright thanks guys this is bens FRIEND not him he wanted me to say that.
Username: Quirky
SA, Texas
Post Number: 74
haha ok ok =( it would be cool to get it to work though. alright thanks guys this is bens friend
Username: Quirky
SA, Texas
Post Number: 76
just a few pics. not hooked up. just what i was planning. thats a 1.25amp battery charger and the battery is a 12volt, 20amp hours @ 10hr rate.
http://img486.imageshack.us/img486/3651/0320071916ef2.jpg
http://img410.imageshack.us/img410/4177/0320071917lz3.jpg
Username: Hgihkcin
Lincoln, NE
Post Number: 110
you wouldnt get that much use outa that, and its dangerous. http://cgi.ebay.com/ebaymotors/RV-trailer-Inteli-POWER-CONVERTER-12-volt-NEW-60- amp_W0QQitemZ280093686480QQcategoryZ50070QQrdZ1QQcmdZViewItem
the thing above is a converter from 120v to 12v with 60 amps, you could hook that upto ur amp, but you wouldnt get full power. and then buy a sealed battery and you could charge it up when ur not using it.
Username: Imi4tth3w
Texas
haha yeah i figured. btw this is the friend that used bens account. but that thing looks pretty cool i may look into one of those sometime. thanks for the help
Username: Jesse59672
OK
Post Number: 142
my house system hits harder than yours :-)
Username: Jtown
Post Number: 26
yeah def buy a converter, thats the way you need to go
Username: Arande2
Extreme SQ FTW
Post Number: 2014
My house system hits pretty hard when I want it to. But then again I get said when I have all the 12s at Xmax and I want more
