Need new subs
Username: Ceoofdaroc4
Post Number: 73
what subs should i get im thinking of getting type r's bcuz these L7s rattle my damn back dashboard too much which makes the bass osund terrible plus my box has air leaks and is too big?? so what subs should i get that wont cost a fortune i want deeeeeeep bass.
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 1475
Do you want a sub that can hit the lows?You need to state a budget as well.You're probably going to have rattles no matter what you get if you have loose paneling and stuff like that,I reccomend you go through your vehicle with some weatherstripping for a quick fix of rattling plastic panels or go with some Edead or Dynamat.That's the only way to eliminate rattles becuase if you have any sort of loud bass it's going to rattle your vehicle.
Username: Drivingreckless
DD 9515f, 146.2 db Mov...
Post Number: 3138
get a 15" AA havoc
Post Number: 74
man i have a mazda millenia small trunk most im fitting in there is 2 12" im not trying to spend more than like 400 on the subs im a cheap azz. how do i do this weather stripping thing??
Username: Dakangofkrunk16
Post Number: 26
if ur gonna get a alpine get the type X my friend just has on and it hits nice in a right ported box there are other subs but i c ur leaning towards alpine so i suggest that
Post Number: 27
trust me i now all about being cheap check da name lol
Post Number: 76
nah im not leaning towards anything i jus here ppl on here say there nice and my friend jus ordered some but every1 on here say the type R is way nicer than the X and its cheaper
Username: Th3pwn3r
Post Number: 1477
You can buy 1 type R and get yourself a TCAB box made by Mark Potts and it will be LOUD.
Post Number: 28
here are other suggestions
http://www.sonicelectronix.com/item_3852.html
http://www.sonicelectronix.com/item_3870.html
i had those sold them to make money 4 w7
http://www.sonicelectronix.com/item_8246.html
these are ok i guess
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1516
Username: Bumpndatrunk
Milwaukee, WI USA
Post Number: 44
how do we get in touch with mark
