Silver Member Username: NorthomahaPost Number: 185 Registered: Mar-06 | Hey guys, I was wondering if anyone on here already had a box design for a alpine type R 15". My buddy has one and were gonna build him a box tomrow, this will save me lots of time if anybody has anything, thanks alot! |
Silver Member Username: NorthomahaPost Number: 188 Registered: Mar-06 | can somebody at least give me a link to that site where it creates a box with your specifications |
Bronze Member Username: Rob1083Post Number: 53 Registered: Mar-07 | vented or sealed |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 182 Registered: Jan-07 | well no... do some work yourself... go to alpine.com download the manual for the type r and get the specification needed and fill this: http://subwoofertools.com/forum/ported-box.asp and then you go... |
Bronze Member Username: Rob1083Post Number: 54 Registered: Mar-07 | it gives you the external box dimensions right there in the manual just make it that size then make your port 1.5x15x27in. deep. |
Bronze Member Username: Rob1083Post Number: 55 Registered: Mar-07 | it gives you the external box dimensions right there in the manual just make it that size then make your port 1.5x15x27in. deep. for vented |
