1000/1 Powering
Username: Skibum12189
Cleveland
Post Number: 346
I was reading up on a JL 1000/1 and unlike most amps it says it does 1000watts@1.5-4 ohms.....does this mean it will stay at 1000 through all those impedances, or does JL just not say that itll do 1400 wat 1.5 and 800 at 4 ohms or somethin bc most amps say 1000@2 ohms or w/e not 1.5-4. Are JL amps just phenomenally efficient or what? Any explanations? JW -Thanks
Username: Rob1083
Post Number: 50
no' it will stay right around that output from 1.5-4 ohm loads
Username: Hockeyknight
Post Number: 973
its a regulated power supply so u will always get 1000w
Post Number: 974
^^^^^i think^^^^^
Username: Rob1083
Post Number: 51
read this
http://mobile.jlaudio.com/products_amps_pages.php?page_id=46
Cleveland
Post Number: 349
thanks guys, gotta love the question being answered in less than 10 minutes.
Idk if this is on JLaudio.com, prolly is haha, but would it be safe to run a 1000/1 at 1 ohm or would most of you not wanna risk burning out your amp.
Username: Ctmike
Ct.
Post Number: 3669
i've seen them attempt to run at 1ohm. the few times i have they went into protect pretty quickly.
Username: Rob1083
Post Number: 52
for that price i wouldn't risk it
Username: James1115
Use a simple...
Post Number: 9687
any sub that you need to run at 1 ohm you can also run it at 4 ohms so why take the risk when you get 1000 watts whether its 2 ohms or 4ohms or 1 ohm power is power.
Username: Dakangofkrunk16
Post Number: 9
that amp is basically made for jl audio w7 because of the 1.5 impedance load and to be honest the lower the ohms the better it seems to be according to ohms law http://mobile.jlaudio.com/pdfs/594.pdf
Username: Naledge503
Enter Here!
Post Number: 1181
It would be better if we werent talking about this particular amp. And it would only be better for getting more power out of your amp. This amp has the same output from 1.5-4 ohms. Do you honestly think that JL's are the only subs with a different ohm load other than your basic 2 ohm and 4 ohm subs? My subs are dual .7 ohm.
Cleveland
Post Number: 350
good call James i didn't even think of that. but yea i dont think id risk it on a almost thousand dollar amp, but yea thanks guys i think that answers about everything.
