Which should i use
Username: Purecamry
i have two 12 inch subwoofers each at 1400w and 4 ohms
which should i use
1000W 4-Channel Power Amplifier
or
1100W Digital Monaural Power Amplifier
Username: 04redmach1
Columbus, GA USA
Post Number: 432
So you don't screw up too bad, first tell us the brand and model of your sub and is it DVC or SVC. Next, what brand and model amp are you looking at? Brands on electrical is like brands on a car.
Kevin
Username: Purecamry
theses are the specs
there all panasonics
Size 12"
Peak Input Power 1400W
Frequency Range 18Hz - 3kHz (-10dB)
Sensitivity (S.P.L., dB/W/m) 89
Nominal Impedance 4 ohms
Magnet Weight 45 oz
Mounting Depth 5.492"
Mounting Location trunk
Wide Rubber Edge Yes
Cone Material High rigidity mica/polypropylene composite oven cone and center cap
4-layer Voice Coil Yes
Large Dual Dampers Yes
Diaphragm with Large Center Cap Yes
Screw-type Terminals Yes, gold-plated
High Power Handling with minimum distortion Yes
Username: Purecamry
Size 12"
Magnet Weight 45 oz
Columbus, GA USA
Post Number: 433
Hmmm, can't give you an honest opinion on those. What kind of budget are you working with for 2 12's and amp?
Kevin
