How do i hook a remote wire to a switch?
Username: Explictx
Glen Burnie, Maryland USA
Post Number: 66
[IMG]http://i40.photobucket.com/albums/e215/jcoleman134/SSPX0039.jpg[/IMG]
Thats the switch i have. how do i hook my remote wire to it?
Username: Killswitchjd
Post Number: 291
bad picture....
Username: Explictx
Post Number: 69
i know bad camera phone. sorry. i got it though, thanks anyway.
Username: Nd4spd18
Southeast PA
Post Number: 840
Yeah that pic sucks, but it looks like the switch has 3 terminals? If so, do this:
Turn the switch on. Use a DMM set to check continuity (the setting where it beeps when you touch the probes together), and probe the terminals. When the meter beeps, turn the switch off and it should stop. You have found the terminals you want to use, now mark them. Then, connect the amp's remote wire to one of the terminals, and connect the other one to your accessory power wire.
Username: Explictx
Post Number: 70
Yeah thats one of the reasons why im getting a new phone . Yes it has three terminals. i used to the the two outside ones and it works fine. Thanks.
Username: Dkchillin
Vermont
Post Number: 406
That third terminal is probably for a small led on the top of the switch. If you wire it to a ground, it'll light up when it's on.
