your disec/switch is bleeding sigal from other ports. Istill works leave it alone until it completely dies. Than replace. In my opinion, tinkering only causes more problems and frustration. Buy another and have it in reserve for the day it is really needed
El Chino dont hijack the thread the guy is asking about 2700 so respect that open your own thread . no help for you in this thread. learn guy how to not highjack threads.
abbasi all you have to do is turn off your reciever from the back for couple seconds and turn it on it will fix the probelm ok .
I have powered off the pansat 2700a couple of times but the problem remains.
To give you more details I have 2 x pansat 2700a and 2 disec switchs with 2 Dish's. One receiver is working perfect and I am having problem with one unit. When I move the faulty pansat and put it in place of the working pansat, faullty status remains the same.
That makes me think that the switches are fine, cables are fine, dish's are fine and even upgrading to new bin does not help.
When U move the bad one to the good one position...U need to change recheck the antenna settings again, AND reboot the receiver with REAR switch...and it sounds like the bad one didn't take the upgrade sucesfully possibly ...but U do NOT describe the problem and screen reactions and messages, so its impossible to pinpoint the problem...
BTW...does the good one work in the position of the bad receiver?
Has the "bad" receiver EVER worked?
Have U bypassed the switch and gone directly from LNB to receiver?...what have U done to try and remedy your problem, other than swap receiver positions?
BTW...are U sure 1 is NOT a clone?...have u opened up the casing and looked around for anything like a bad fuse or solder..most likely U did NOT perform the upgrade correctly, but I dunno what U did..
I will check if it is a Clone. As far as the upgrade is concern, it was a working unit, stopped working, and I found that it was showing 99% signal on all satellites. I upgraded the firmware and bin but the sysmptoms are the same.
Nobody has said what the problem is yet.."stopped working" is NOT a description of a problem..neither is "faulty"...thats like me calling my car mechanic on the phone and saying "my car is broke, whats wrong and why?"...he would laugh at me, he doesn't have a crystal ball either..
U need DETAILS instead of generalities!...hey , if Future-FTA has a thread about whatever this unknown "problem" is, then everyone can get their solution there..which is what people should do anyway, by using the sites that specialize in specifivc receivers...thats why I have the "RECOMMENDED Reputable satellite sites " thread posted here in these forums!
