New member Username: KapreseWalstonburg, NC USA Post Number: 2 Registered: Mar-07 | What people I am new up here and I was just wondering what should I set my HU bass and Sub-output to have it on the average level but not to much were as in something will blow or burn into flames I have a Panasonic CQ-8300 and a Kenwood KAC_8101D (mono) 200w@4 ohm and 400@2 ohms.Plus a sealed box for my Volf. subs 500rms.I know they have a bad rep. but they pound in my small Saturn.PLease leave any recommendation or a better setup or arrangement (rambling on I know) |
Bronze Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 98 Registered: Feb-07 | i love bass i got my sub's all the way up to 7 and the bass at 0. i'm pushing 2,300w on two 12 RE SE |
New member Username: KapreseWalstonburg, NC USA Post Number: 4 Registered: Mar-07 | Do you think I should push my Volfenhag that hard or do you think I should lay off the bass a little everyone else tells me not to play them to hard but for me they DROP HARD what do you think |
New member Username: KapreseWalstonburg, NC USA Post Number: 5 Registered: Mar-07 | Also my sub box is in the trunk and is rear firing do you think I should have it as close to the trunk as possible or give it some space to breath,I have a small trunk so how should I place my sub box close to the trunk or back off a little.I also have a Saturn with fold down seats |
Bronze Member Username: KapreseWalstonburg, NC USA Post Number: 18 Registered: Mar-07 | I wish someone would respond or give me some tips on getting more SPL or something I could do with me setup ? |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11848 Registered: Jul-05 | what is ur preout voltage on ur HU?? |
Gold Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 1574 Registered: Sep-04 | Also my sub box is in the trunk and is rear firing do you think I should have it as close to the trunk as possible or give it some space to breath,I have a small trunk so how should I place my sub box close to the trunk or back off a little.I also have a Saturn with fold down seats See this: http://www.teamrocs.com/technical/pages/aiming.htm Rear fire em as close to the back of the trunk as possible, within reason of course. You don't want the cones smashin into anything. -Fishy |
Bronze Member Username: KapreseWalstonburg, NC USA Post Number: 23 Registered: Mar-07 | 5 volt |
Bronze Member Username: KapreseWalstonburg, NC USA Post Number: 24 Registered: Mar-07 | How do you suggest getting more SPL out of my system or setting my HU just right.What else do I need to make what I have better ? |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11862 Registered: Jul-05 | and what is the voice coil config on ur sub?? |
Bronze Member Username: KapreseWalstonburg, NC USA Post Number: 33 Registered: Mar-07 | DVC |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11886 Registered: Jul-05 | 4ohm or 2ohm?? do u have aim??this forum is way to slow, and i no u want to get ur stuff right |
Bronze Member Username: KapreseWalstonburg, NC USA Post Number: 36 Registered: Mar-07 | 4 DVC subs and nah I don't have aim and each set of voice coils is 250watts so each sub is 500rms |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11890 Registered: Jul-05 | ok..theres the problem..ur subs are dvc4ohm so wired together the will create a 1ohm load...ur amp is not 1ohm stable nor is it enough power for those subs... this is the only way to wire them with out any problems..but it is at 4ohms and ur amp only produces 200rms at 4ohms...so thats 100rms per sub...so ur underpowering them by 400rms per sub..u need another amp.. |
