Anyone who hijack a thread should not be helped
Username: Cartier1
Post Number: 314
just like anywhere eles dont hijack a thread dont hijack a thread. it makes a confusion and the thread loose it's value.
Username: Lklives
Post Number: 8271
We could spade or neuter them!
Username: Ryersonarmy_1
RYERSON, @ PEACE ... What a...
Post Number: 295
where are the keys
Username: Digitalnuke
Post Number: 25
Which card is most likely to be hacked first, the P4, or the P5? And what kind of programmer will I need. Thanks.
Username: Cartier1
Post Number: 316
ryerson check your moma pockets for the keys.
Username: Cartier1
Post Number: 317
Ralph Kramden the card most likely to be hacked first is your fucccccccccccccccking credit card. not the p4 not the p5 is your fuckkking master or visa. about the program you need to go to : burn your credit . take the money and not paying a dime and file for bankrupcy.
we are talking about an issue of not hijacking not your fuckinggggggg cards
by the way it's not called anymore P4 or P5 . it's called pennisssssss4 and pennisssssssssss 5. dickkkkkkkkkkk head.
Username: Lklives
Post Number: 8277
To the moon Alice!
