I went to get my amp for the cvr124......going to get the zx850.2....however it was not in stock....so the guy said he has a zx750.1 and will switch my cvr124 for cvr122 (no charge) and 350 for the amp and install....sound okay????...remember guys I am so new to this ( he is an authorized dealer and everything is new
well the 750.1 does 375 watts at 4 ohms and 750 watts at 2 ohms..
this would be a great amp id you plan on upgrading to 2 cvr's.. if you dont plan on getting 2, then theres no point of getting this expensive and big of an amp... the rms on the cvr is 400, so make sure you get the dual VC 2 ohm sub. BUT, if i were you, i would get 2 cvr's b/c there is no point in gettin that big of amp for that small of sub
