Silver Member Username: Volfenhagking1600I WILL be 15 Wangin Post Number: 385 Registered: Oct-06 | I ripped off my carpet that i had on my old box and im going to fiberglass it...anyways i need to know if there is an easier way getting the glue off the box than sanding? |
Bronze Member Username: Surferdude9371Maitland, Florida Post Number: 34 Registered: Mar-07 | you cant fiberglass a box so to speak. it doesnt stick to wood youd have to start from scratch and use fleece. look at this url http://www.the12volt.com/installbay/forum_posts.asp?TID=74519&PN=1 its how i learned but know you have a lot of rigorous work and large amount of time ahead good luck and make sure you wear long sleeves when you sand. |
Gold Member Username: J_baby15Kentucky Post Number: 1365 Registered: Feb-06 | u sure man? plenty of ppl here resin their boxes. im sure u could just resin or put mat on teh outside and sand it down and itd b right. the fiberglass should cover up the glue thats left i would think. |
Bronze Member Username: Surferdude9371Maitland, Florida Post Number: 36 Registered: Mar-07 | i never had luck with gettin it ta stick but if people do ask them how they do id like ta know lol. remember if you glass over the glue thats a highspot you have ta sand down later and fiberglass itches like hell. |
Gold Member Username: Van_manBoston South, MA Post Number: 2207 Registered: Mar-06 | Belt sand with 60 grit or angle grinder. then You need to clean and dewax the wood with acotone. |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3816 Registered: Jan-06 | why are you fiber glassing the outside |
Silver Member Username: Volfenhagking1600I WILL be 15 Wangin Post Number: 388 Registered: Oct-06 | something to do |
