New member Username: MotokorteRoyal oak, Mi Usa Post Number: 2 Registered: Aug-06 | I have a lady that wants her new plasma mounted. do you guys install new electrical outlet also. I would like to install a new catv cable, as i dont want to splice hers twice. |
Gold Member Username: John_sColumbus, Ohio US Post Number: 1417 Registered: Feb-04 | I'm no electrician, but I believe it is against code to run a standard power cord through a wall. http://www.hometheaterblog.com/hometheater/2006/05/howto_wall_moun.html http://www.soundandvisionmag.com/tutorial/1406/step-by-step-how-to-mount-a-flat- panel-tv.html |
Silver Member Username: WestcottLeague City, Texas Post Number: 169 Registered: Oct-05 | I ran power with in wall rated power cable from the nearest outlet, through the wall, to a new outlet behind the display. With a flat panel, the last thing you want to see is wiring, power or audio, video. If you are not comfortable with electical work, get a professional. |
