Archive through March 03, 2007
Username: Jpz
MTL, QC CAnada
Post Number: 173
new DN keys please
Username: Kennyg
bev keys anyone ?
Username: Bertoro
Toronto, Ontario Canada
Post Number: 498
bev
7A 9A 59 DD 0A E6 F9 79 F8 3E A6 9F FB 79 20 7B
C5 3E 7C 37 FB 3A 86 16 70 B6 59 8C 91 03 EE 7E
Username: Berrtles
these keys dont work, are there new ones?
Username: Sirroy
Edmonton, Alberta Canada
Post Number: 13
Thank you Bertoro
Username: Sirroy
Post Number: 14
Does anyone know how to update Autoroll?
Username: Manthedent
Post Number: 17
hey guys well no one answered my !!! no one knows if there is a way to get the rest of the arabic chanels on my pansat 2300? :-(
Username: Dude123
Post Number: 950
Roy Todd,
Just update your bin file
Username: Nestea
Post Number: 65
Bev new keys
Key 01: 7A 9A 59 DD 0A E6 F9 79 F8 3E A6 9F FB 79 20 7B< active
Key 00: C5 3E 7C 37 FB 3A 86 16 70 B6 59 8C 91 03 EE 7E
Username: Atul_shah
Post Number: 18
The One,
Per you advise here is the System Information
SAFE
AP1:2.72 Tiv0
Boot ver: 6.2
Username: Atul_shah
Post Number: 19
The One,
per you advise her is the system info reads
SAFE
AP1:2.74 Tiv0
Boot ver:6.2
Username: Stephane
Milton, Ontario Canada
I seem to have lost over 100 channels. I have a viewsat extreme. I am not sure how to retrieve these channels. Thanks
Username: Atul_shah
Post Number: 20
Can anyone help i am trying to get CNN, cartoon and other local channels.
My Bin file is
SAFE
AP1:2.74 Tiv0
Boot ver:6.2
Username: Scuffy
just got two Viewsat Extremes and set it up with directv DUAL LNB. each LNB has two lines, two110 two 119,each line from 110 and 119 go to different DiSEq switch and from each switch go to each box. But the problem is i cant watch two boxes at the same time, it will freeze or the quality will drop. In order to get one working i have to turn one off. How do I keep both Viewsats working together?
Username: Dude123
Post Number: 951
Atul
You are using an old bin file, I would suggest you go to one of the following websites and upgrade your bin file, download the bin file on your computer. You also need to download the loader that loads the bin file onto the receiver, and you need a straight through cable (connects receiver to the PC). Get all that first and then i will give you a step by step direction how to upgrade it on to your receiver.
Here are the links:
www.dssevolution dot com
www.totalfta dot com
www.dsscommunity dot com
www.dsscentral dot net
Username: Yarda_666
Post Number: 21
I just lost every channel. not only the ones you need the codes for. I lost even Gol TV. New codes or new bin anyone? this is for a pansat on DN
Username: Jpz
MTL, QC CAnada
Post Number: 174
hi guys, what is going on with DN
Username: Eechag
Montreal, Quebec Canada
Post Number: 44
Bev is down, please provide new keys. thank you.
Username: Atul_shah
Post Number: 21
The ONE,
Thanks for your resonse. Since, its so confusing to which file to be dowmloaded. I appreciate if you can send me any new file you may know off. Also, the instructions to setup.
Thanks again
-Atul
Username: Nehal_3278
C, D C
Post Number: 8
plz send me key for BEV 0901
Username: Bertoro
Post Number: 499
bev
86....CF 01 3E 6B CF 11 A4 BC 05 B5 1E 3E 14 E0 96 A0
96....86 33 68 E6 15 84 E0 ED DD BA BD FE DD 2E 89 6B
Username: Alwyzlosty
Post Number: 58
is anyone else havinf problems with dn pnsat 2500a i am loosing everything maybe new keys needed!
Username: Ginitalexa
Post Number: 10
When you nedd the new keys, just go to
tvkeyz.com}
Username: Tata3401
Post Number: 37
Hello Guys:
I am having a problem with my panset 2700. It was working fine (except failed autoroll) till last week. And then I loaded the new bin 295. Since then I am not getting any thing. When I tried to load all the channel again, I do get Level almost 90% but quality I am getting is 0%. Also, my satelite ECHO 8.6/ku is missing and only have ECHO 3/ku. Before I had 8.6/ku as well. I tried to load channel with Echo 3/ku and tried all Disq (from 1 to 4) and all TP (0 to 32). But still never got quality more then 0%. Tried blind scan and still didn't get any channel.
Can someone help me what's the problem? What I am doing wrong? Thanks a lot .... in adavance for your help, guys.
Username: Mathiaparanam
i am trying to get bell nimiq1. after i scanned m channel, its able watch them. i am getting scrambled or bad channel. some one can help put please.....
Username: Mc_sunny
Post Number: 1179
Dish New Keys:03/01/07
Key0: 2A81C78E397F7F09AA5B0253D0EA7F7B
Key1: B388CD6095962C11C0B115D078659A10 <-Active
Username: Tata3401
Post Number: 38
Hello Guys:
Username: Angie_wedgewood
Post Number: 20
Bev just went down... Does anyone have the new keys? Please and thank you.
Username: Curler
Angie, active keys changed from 01 to 00. Check keys above, u probably didn't update your 00 key.
Username: Sirroy
Post Number: 15
Hello! Can anyone tell me how to update VS 2000 Ultra as in Autoroll if possible. Thanks
Post Number: 21
Yeah it still doesn't seem to be working. Odd. Thanks anyways tho.
Username: Sirroy
Post Number: 16
Does anysone have the new Bev keys. Please and thank you.
Username: Thunder_lightning
Post Number: 51
KEYS..[link removed]
[link removed]
http://www.filez.us/km3/keys.shtml
Username: Mav444
Post Number: 35
thanks for the info Thunder
Post Number: 55
Steve no problem..
Username: Palikeroako
Post Number: 41
can someone please get me the keys for the D.N.
Thanx in Advance...
Post Number: 68
O dogg..check my post up there..
Said keys and the 3 links..
Post Number: 42
Those keys dont work...
Post Number: 71
IT work i am watching DN right now..turn Auto off..turn off your box from the back then turn back on..
86: 2A 81 C7 8E 39 7F 7F 09 AA 5B 02 53 D0 EA 7F 7B
96: B3 88 CD 60 95 96 2C 11 C0 B1 15 D0 78 65 9A 10...Active
Username: Samson
Post Number: 7
Please tell me where to find a loader and bin for Megasat 4000XL. Thanks
Post Number: 74
alan go here..
http://www.dssrookie.com/forums/
http://www.dssevolution.com/index.php?
Username: Larry1
Dawson creek, Bc Canada
Post Number: 22
any budy have the latest bev keys thanks
Post Number: 75
BEV KEYS..
Key 0: CF 01 3E 6B CF 11 A4 BC 05 B5 1E 3E 14 E0 96 A0 (Active)
Key 1: 86 33 68 E6 15 84 E0 ED DD BA BD FE DD 2E 89 6B
Username: Thetop
I need the new bell codes
Username: Dude123
Post Number: 952
Keys haven't changed for BEV since 28th February and for DN since March 1st.
Nagra2 Keys
Dish Provider 0101: Last Updated (March 1 12:30pm EST)
Key 0: 2A 81 C7 8E 39 7F 7F 09 AA 5B 02 53 D0 EA 7F 7B
Key 1: B3 88 CD 60 95 96 2C 11 C0 B1 15 D0 78 65 9A 10 (Active)
Bev Provider 0901: Last Updated (Feb 28 7:00pm EST)
Username: Agf
Toronto, Ont Canada
Nagra2 Keys
I have the correct keys but the signal is 0%, Could anyone tell me what is the problem. Thanks
Username: Bertoro
Post Number: 502
agf..do u have 01 as active?
have you turned off and back on your box, form behind switch?
Username: Ben333
Hi everybody,
please can u explain me what means (active keys)for Bev?...thanks
Username: Cartier1
Post Number: 177
hamid the active key is the one that is working . when the keys are changed . you only change the active one .
Username: Tata3401
Post Number: 39
Hello Guys:
Username: Jpz
MTL, QC CAnada
Post Number: 175
hi guys
Username: Cdeepak
I gave up on Ariza Xtreme. no bin yet for Ariza Xtreme.
Going to buy Viewsat tomarrow, ?
which is better?
Viewsat Xtreme or Platinum?
Post Number: 77
Viewsat ultra 2000 or Viewsat Xtreme...
DC..pick that 2..
Username: Mkvl1490
Post Number: 100
i have a question, i scanned tha channels in, but i only got a few radio stations. and i want to listen to shade 45, but i cant get it. can someone help?
Username: Joe123xyz
Post Number: 26
Hi guys, I have same problem as AGF, can somebody please help. Thanks.
Username: Joe123xyz
Post Number: 27
Guys, this is what I have: entered right keys, Level and Quality are really low, and No channels. I would like to see the boxing tonight. THANKS.
Username: Roundtree
Post Number: 25
DN keys rolled again? Can some please post the latest keys for Pansat 2500A clone. Keymaster 3.0 and Key Ripper 3.1 still showing old keys.
Username: Larry1
Post Number: 23
is there any new keys for bev thanks
Post Number: 25
Nope Larry, the keys are still the same for bev since the 28th of Feb.
Username: Larry1
Post Number: 24
thanks a lot
Username: Curler
bev gone down. Anyone have the new keys?
Username: Eatfish111
Post Number: 221
00: 4F 81 BE EB 4F 91 24 3C 85 35 9E BE 94 60 16 20
01:DE FC 22 98 11 46 D0 63 E2 88 F9 D0 8D D1 0A 8A
Username: Shm
what about DN
Post Number: 222
dn hasnt changed for a couple of days.
Username: Nasrin87
I don't know what the rest of you guys but those keys dont work for me
Username: Curler
Those are thekeys I have, don't work for me, are they alright for you?
Username: Nasrin87
NOPE
Username: Larry1
Post Number: 25
the nunbers are right but still scrambeld
Username: Larry1
Post Number: 26
the numbers are right but still scrambeld
Username: Nasrin87
OK Never mind
I got the keys which works for me
it's:
00, 86: CF 01 3E 6B CF 11 A4 BC 05 B5 1E 3E 14 E0 96 A0
01, 96: 86 33 68 E6 15 84 E0 ED DD BA BD FE DD 2E 89 6B
Username: Molari
Post Number: 21
Nasine...those keys Bev or Dish?
Username: Curler
Thank you very much. They work fine.
Username: Nasrin87
for BEV
and its NASRIN LOL
Can someone tell me why these keys keep changin from
to
Eventhough the first one works and NOT the second one ????
Username: Wlyman
Bozrah, Ct U.s.a
Post Number: 12
dn no roll turn on and off reciver will come back on
Username: Agf
Hello ferenck massella,
I figured it out. Switch off your receiver and switch on again. then do a blind scan, make sure it is SAT-31(Indian ch) or the one you want and let it scan.
It should scan and come back up, if need be put these keys
Have fun.}
Username: Curler
bev has just gone down again
Username: Larry1
Post Number: 27
put last keys in turn off autorole they work
Username: Nasrin87
Thanks Wayne
Username: Curler
thanks
Username: Larry1
Post Number: 28
go to tvkeyz.com-latest nagra II keys for new numbers
Username: Kipy
iam confused, iam using c00lsat 5000 plat, with bin 141, my autoroll isnt working, and iam not sure what set of keys to add in for BEV, or if there is anything special i need to do.
Can anyone help me?
Thanks,
Post Number: 82
Bev Provider 0901..just enter Bev keys in then watch http://www.filez.us/km3/keys.shtml
Username: Larry1
Post Number: 29
for the latest keys go to keymaster nagra II keys
ll
Username: Kipy
Post Number: 7
i just entered these keys:
Bev Provider 0901: Last Updated (Mar 3 9:20pm EST)
Key 1: 1E 3C E2 58 D1 86 10 A3 22 48 39 10 4D 11 CA 4A (Active)
and BEV still not working, i waited for a long while, and autoroll been off.
Post Number: 83
...just changed,
keys 00...8F417E2B8F51E4FC45F55E7E54A0D6E0..active
Username: Molari
Post Number: 22
Bev is churning out fake keys.
Anyone have both "00" and "01" updated Keys for Bev?
Username: Curler
Post Number: 7
tried them and they don't work.
Username: Typertegra
Vancouver, British Colu...
Post Number: 21
dont work
Username: A6ali
i tried the above bell keys they dont work for me as well
Username: Kipy
Post Number: 9
i just entered that in THUNDER and still nothing on BEV...
Username: Molari
Post Number: 23
Turn off autoroll.
Bev is putting out fake keys.
Username: Dmc0923
tried the numbers, not working for me either
Username: Hardrockstriker
Post Number: 673
Just wait a few more minutes guys. Usually for every key change two key changes occur and we only get the first. It takes a little longer to get the "final" keys.
Post Number: 674
Bev Provider 0901: Last Updated (Mar 3 10:20pm EST)
Key 0: F8 47 F3 E5 91 A9 0B 04 97 C2 57 0F B4 33 BC 2F(Active)
Username: Curler
Post Number: 8
nope, these don't work either.
They don't want us watching the ufc 68 thing
Username: Kipy
Post Number: 10
screw UFC, i miss simpsons ;)
Post Number: 85
TRY THIS..
BEV..Key 1: 5E 7C A2 18 91 C6 50 E3 62 08 79 50 0D 51 8A 0A (Active)
Username: Curler
Post Number: 9
okay these work
Key 0: 8F 41 7E 2B 8F 51 E4 FC 45 F5 5E 7E 54 A0 D6 E0
Post Number: 675
-96- is Active Changed Sat Mar 03 22:24:17 2007
* 86:CF013E6BCF11A4BC05B51E3E14E096A0
* 96:5E7CA21891C650E3620879500D518A0A
Username: Kipy
Post Number: 11
no that still not working for me :-(
