Hi, I'm a newbie at this forum; so, please forgive me for a question which might be a FAQ. Anyway, I recently got pansat 2700 from my friend with current bin files loaded in it for 3Ku (61.5W) sat. Due to miscommunication I brought DTV phase III dish, with 3 LNB and integrated switch, and later found out that it is not an ideal dish for viewing 61.5W. Well, here I was and I decided to give it a try, so, I setup my dish pointing to sat and tried to set it in my pansat box.
Here is the setting I'm using --
LNB Type - Standard Freq - 11250} 22KHz - ON (if I set it to OFF I do not get 0% quality) Skew - -45 TP - [29] Diseq - #1 Legacy SW - None Position -- Disabled
After configuring above settings, I'm able to get most of the channel from 61.5 but not all of them. Notablly, I'm missing few Indian channels those I wanted most.
Can someone please help me to get those extra missing channels?
congrats and getting anything with that dish..most likey the dish needs a slight readjustment to get more of the 61.5 channels...
U need to provide more info too though, since some pansat bins bins are having problems with intenational channels..need some specifics provided t get some help from here...also each channel is assigned to a transponder, and possibly U only need to scan the transponder/s to receive the missing channels..
Actually I do like that dish if you know what to do with it Most people won't get international 61.5 if you point to 61.5
- What I will do is point to 70 degrees and you'll get both 61.5 and 82 (It will work trust me) - So move your dish slightly 5 to 8 degrees clockwise LNB-1 will pickup 82 LNB-2 will pickup nothing LNB-3 will pickup 61.5
What you'll get some canadian BEV and all international DN
Make sure you get latest BIN PGM and do 61.5 setup first King
LK- I got the list of TPs for 61.5 from lyngsat site and I'll give it a try today. Hopefully some fine adjustment should solve my problem. King - Once I'm done with above I'll try your configuration.
If you do what I tell you you may not need to miss with TPs. I consider LK as an expert I'm sure he'll agree with me.
I'm not saying pansat bins don't have problems But moving the dish 5-8 degrees clockwise is the right thing to do for DTV Ph-III. You'll come back and thank me.
If the middle TP is pointing to 61.5 you are trying to milk a bull it won't work middle LNB ain't compatible. Just move your dish and save your time and hassle.
- First If you are using any switch let me know before you start setup - Make sure you load correct bin PGM and you are not using clone etc. - move your dish like I mentioned above - One wire straight to your reciver no any type of switches (coupler is ok) - Antenna setup echo St-3 (61.5W)
LNB Type - Standard Freq - 11250} 22KHz - OFF Diseq - #1 Legacy SW - None Position -- Disabled
- Do blind scan followed by Sat chan Scan - Let me know how it worked Good Luck
This Clock is just a reference in their orbit location 61.5 and 82 is what you'll be getting with this dish Big Boss LK will agree with me I know he is an expert
I'm able to get missing channels. Here is what I did - 1) Changed the 22Khz setting to OFF position from ON (I use to get most of channels by setting it to ON position, but never use to get any signal quality on TP12 with this setting, So, I changed it to OFF (Thanks to LK for pointing to lyngsat site that told me - TP 12 is one which will provide missing channels. Also thanks to King for reassuring OFF setting) 2) I rotated dish few degrees clockwise, as advised by King, until I got full signal for TP 12, and then I did a full scan.
I just want everyone to know: - That first trick I learned from LK was DTV phase-3 - It was my first struggle - LK has more hands on than anyone in Satellite - I do give full credit to LK I LOVE TO BUST HIS CHOPS I'm always kidding around, but I won't give false information. Advice I give is based on other related experience that I do for living. They are real
I don't have any international or BEV and I didn't even test any of it. I love to experiment with Satellite. King
The Phase III oval dish (FAQ) All about the Phase 3 dish (made for DTV, has 3 LNBs in same enclosure and built in multiswitch.) YES, you CAN use this for your FTA setup to get 91 and 110 !
Advantages 1. You can add 2 LNBs and get 82 and 119 too on same dish. 2. Cheap or free from your DTV system. 3. Use only one wire and get 2 sats. 4. If u add 82 and 119, you'll use 3 ports on your diseq switch.. perfect to hook up an additonal bigger dish and a linear LNB and get birds like Intelsat 5 (T5) on your diseq empty port.
Connection 1. You need only 1 coax cable per receiver connected to the Phaze 3 dish, which is an advantage. 2. It doesnt matter which of the 4 ports you connect to. All 4 are the same in functionality. Your receiver will use the built in multiswitch to select one of the 3 sats. It does that via voltage change and 22khz tone signalling.
What this dish is for and how it was meant to work 1. This dish is for DirectTV. Was made to get the 101, 110 and 119 DTV sats. 2. Looking from behind the dish, the LNB are used like so: .......left lnb = 119 sat ..middle lnb = 110 sat .....right lnb = 101 sat 3. The multiswitch inside uses 22khz tone that is sent by your receiver to switch between 2 sats (just like any other 22khz switch). You'll have to set that up in your Pansat receiver. 4. 2 sats?? Yes! The multiswitch inside also serves as a combiner to combine signal from 110 and 119. So the 22khz will switch between the signal of 110 and 119 combined and the signal of 101
How the built in combiner works 1. The combiner takes TPs 2, 4, 6, 8, 10, 12, 14, 28, 30 and 32 from the middle LNB (110) and all the rest of the 32 TPs of the left LNB (119). You cannot change what TPs are combined... Covering middle LNB with foil wont work, cutting traces on the pcb wont work. 2. This is OK for DTV because DTV only has 3 TP's on DTV's 110 (28, 30 and 32) and they are different from the TPs on DTV's 119. (a tp is a frequency band on which up to 14 channels are transmitted). So combining different frequencies on the same wire, works fine. But it will affect your FTA setup.
How the built in combiner affects your pansat setup 1. You can use the Phaze 3 dish to get the 91 (bev) and the 110 (dn) satellites. 2. For that you point the dish to 101 (middle lnb), and adjust the skew. Now the left LNB picks up 110 (looking from behind the dish) and the right LNB picks up 91. 3. The combiner will combine TPs 2,4,6,8,10,12 and 14 from the 101 DTV sat with the rest of the TPs of the 110 DN sat. This means you will not be able to get TPs 2,4,6,8,10,12 and 14 from the 110 sat. but read on to see what your're missing.
What channels will i be missing on my Pansat 1. You will be missing only some local channels. (ABC,CBS..etc..), which may or may not be local to you. Thats it ! 2. To see what is missing you go to lyngsat and check to see whats on TP 2,4,6,8,10,12 and 14 on DN's 110 sat. 4. You will see that ALL but 2 of these TPs are of BEAM type... which means you wouldnt have been able to get them ANYWAYS, Unless you are in the area indicated for that particular beam. 5. The 2 conus (available nationwide) tps that you'll be missing are TP 12 and TP 14. Whats on it? Only locals from Lexington, Knoxville, Jackson and Denver.
What you should be pointing it to, to get 91 and 110 Pansat setup: Assuming you will point this dish to 101 (middle LNB to 101), you will be able to get 91 and 110 on the 2 outside LNBs WITH proper SKEW, and thats what u want do to if you gonna use it with your Pansat. The middle LNB is useless for Pansat setups on Phase 3 dish as it will be pointed to DTV's 101 sat. Also covering this lnb with anything won't help to give u back those locals that you'll be missing. To get the azimuth and elevation for your dish, calculate it for the 101 sat. For skew see below.
DTV setup If you set the dish like above, it will not work for DTV. If you want it to work for DTV you point it to 110 (middle lnb gets 110) and the outer will get 101 and 119. To get the azimuth and elevation for your dish, calculate it for the 110 sat. For skew see below. Or you can use your DTV receiver, enter your zip code and it will give you all settings.
U can't use the Phase 3 dish for DTV and Pansat at the same time because you're pointing to different sats.
How to calculate and use Skew: Skew= vertical offset (twist) in degrees from the vertical (from the 90 degrees mark on your dish) 1. Go to Satellite Nut page 2. Enter your location info. 3. Calculate skew for the 2 outter satellites on your dish (for the pansat setup on Phaze3 that would be 91 and 119) 4. Add them toghether and divide by 2 5. U get the skew number. (Disregard the minus sign if its negative)
To use SKEW: You must ensure that the top of the mast is perfectly plum. Best thing is to use an eye round level (home depot,tools section - $3) that u put right on top of the mast. You do that BEFORE you even put the dish on the mast.
If you are on the EAST coast, skew = counter-clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set your dish to 90 minus the skew number If you are on the WEST coast, skew = clockwise rotation in degrees from the 90 deg mark on your phaze 3 dish. Set dish to 90 plus the skew number
Receiver setup No diseq switch is needed, only one wire needs to be connected to the Phase 3 91: 22khz OFF, Diseq - OFF (or ON - doesnt matter) 110: 22khz ON, Diseq - OFF (or ON - doesnt matter)
Can i also get 119 on this dish? Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the LEFT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB. Receiver setup with the strapped on 119 LNB Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #2, your setup will be: 91: 22 khz OFF, Diseq #1 110: 22khz ON, Diseq #1 119: 22khz OFF (or ON - doesnt matter), Diseq #2
Can i also get 82 on this dish? Yes, if you have an additional DTV or DN (circular) LNB laying around, you can strap it to the RIGHT of the 3 existing LNBs (looking from behind the dish). You will now have to use a DiseqC switch to switch between the wire from the Phaze 3 and the wire from the strapped LNB. Receiver setup with the strapped on 82 LNB Assuming u put the wire from the Phaze 3 in port #1 and the wire from the strapped LNB in port #3, your setup will be: 91: 22 khz OFF, Diseq #1 110: 22khz ON, Diseq #1 82: 22khz OFF (or ON - doesnt matter), Diseq #3
hi my pansat 2700A is currently not working. Which .bin file should i use to see all indian channels. Please help me and also tell me the site where i can download the file Thanks
your question has NOTHING to do with this thread subject!...go read about the 2700 and indian channels ...there are 100 threads and posts here about it...
