Component video?
Username: Deadhorse
Post Number: 42
I have two component videos in on my receiver and one out so if I have a source (DVD, Xbox) going in and then the out into the TV shouldn't it work that way? The TV isn't picking up the signal.
If I go direct to the TV with either source it works.
Username: Samijubal
Post Number: 3361
You have to select whatever input you want to use on the receiver.
Username: Deadhorse
Post Number: 43
I'm in process of setting up and assigning my component video inputs for my VSK-515 and see that the default is Comp 1 - DVD and Comp 2 - TV.
I will run my DVD player into Comp 1 but would like Comp 2 to be my Xbox 360, looking in the manual at the input assign menu I see the choices are DVD, TV, CD, DVR or OFF. What should I choose for the Xbox?
Username: Samijubal
Post Number: 3364
The TV should be the output. There's no need for a TV input. The other input is probably DVR.
