Xmax?
Username: Crayola0
Future 15 Wanger!!, Wisconsin
Post Number: 1759
does anyone know the xmax of the 15" audioque HD3 because i cant find it on their site.
Username: Trey4sports
Post Number: 681
aq and dd dont list xmax, but great subs nontheless
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 650
i believe 2.5 inches. in the table it says usable throw and the 2.5"
Username: Crayola0
Post Number: 1761
ya but when u convert that into mm its like 62.5 mm and that doesnt seem right
Username: Nd4spd18
Southeast PA
Post Number: 851
http://www.ddaudio.com/dd/caraudio/features/xmax.asp
Username: Snarl2004
Post Number: 652
i no i rly not sure. but they do move alot
Username: Crayola0
Post Number: 1763
when i go to the dd site it says gap what is that cause the other part is like 44mm
Username: Nd4spd18
Southeast PA
Post Number: 853
Basically DD and AQ don't measure xmax like other companies. You can't design a box for a DD or AQ sub based on the "suspension" spec, which they list as 75mm for the 9515.
Username: The_image_dynamic
San Diego
Post Number: 498
I already put it on the other thread. The xmax = 31.75.
