New member Username: TiqabaerPost Number: 1 Registered: Mar-07 | Im planning on getting a new system for my cav(only have 4x6s and 6x9s) and have a few questions. Ive been eyeing the HD-642 comp set for a while now, is it good sounding set of speakers? Anyone recommend any brand/type of amp I should get?(#channel & how powerfull) IS there anything i should get to protect the door speakers from the moisture/rain? And lastly, the most stupid of all, should i place the 6.5s in the front door or the 4s? Thanks for reading and thanks for the help. |
Silver Member Username: KillswitchjdPost Number: 285 Registered: Apr-06 | first, all round speakers. in my opinion you cant mix 6x9s with round speakers sucessfully. we need more info, rms of the speakers specifically. and a budget. |
Silver Member Username: Nd4spd18Southeast PA Post Number: 843 Registered: Jul-06 | CDT HD series are awesome speakers. As for the amp, any 100-150watt X 2 channel amp of a respectable brand. Check here for what brands to consider: https://www.ecoustics.com/electronics/products/articles/329117.html |
Gold Member Username: AlteraudiousaConcord Post Number: 1491 Registered: Jan-06 | if you are eyeing CDT products email me. I'll set you up with something nice. I would actually consider something along the lines of the HD-642/M6 with possible HDS-2 for the main tweeter if you don't mind a larger hole for the 2in driver. Amp for the HD 3way is 150-200rms for sure. |
