Bronze Member Username: Ceoofdaroc4Post Number: 43 Registered: Mar-07 | I jus got two 10" L7s (2 ohm) and it says n the manual that a 2 ohm can be wired to a 1 ohm or a 4 ohm load and that a 4 ohm L7 can be wired to 2 ohms or 8 ohms? But I want to run mines at a 2 ohm load does that mean that the ones I have can't be run at 2 ohms that I should of got the 4 ohm ones bcuz I thought that since I got the 2 ohm ones tht commen sense would tell you I could run that at 2 ohms can any1 help me??? O yea I was wondering what model year thy are there silver with a blue center with and S on it thanks guys. |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 4286 Registered: Jul-06 | a dual 4 ohm sub can be wired to 2 ohms or 8 ohms a dual 2 ohm sub can be wired to 1 ohm or 4 ohm |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 4287 Registered: Jul-06 | 2 dual 4 ohm subs can be wired to 1 ohm or 4 ohms 2 dual 2 ohm subs can be wired to .5 ohm or 2 ohm http://www.the12volt.com/caraudio/woofer_configurations.asp |
