Has annyone used rubberized undercoating to seal boxes
Username: Insearchofbass
Post Number: 4996
if so any thoughts whether its less effective than fiberglassing when it comes to coating the inside of the box
Username: 54danny54
KY More Wang Th...
Post Number: 3649
sorry i dont know the answer but...
hey sean, havent seen you in forever man. hows life?
btw it sounds like it would work just as well.
Post Number: 4997
life is good ...havent had time for online much so thats why you havent heard from me .....im thinking that it would seal well and be easier to work with but not provide as much in the way of better airflow...IF glassing has proved to do so
