E-dead problem
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1617
ok so i have 2.5-3 layers of edead on my back hatch in my mountaineer and its still raddling alot. it sounds a little better from the outside but you can still hear it. any other hints to get that to completely stop.
i also took off my back windshield wiper so thats not the problem.
i know its a general question but i dont know if any of you have any secrets. thanks!
Username: Rovin
1 12 Atomic ...
Post Number: 10902
longtime no see u on this forum jake - u still got those ED subs ?
have u used expanding foam inside the door b4 u edead ? - that foam is the shizzle to aid in reducing rattles .......
Username: Frkkevin
Post Number: 3356
sure its your hatch? make sure nothing inside is loose.. like loose parts, cables or w/e that could be slapping something.. if its due to metal flex try liquid nailing some bracing to it
St. Louis, MO
Post Number: 1619
yeah rovin we still have the EDs.
thanks guys ill work on that stuff when i have some time.
