Bronze Member Username: Dave_singh
Post Number: 66 Registered: Jun-06
Posted on can some one please tell me how to put the key in this reciver , thanks i know this pantsat 2500 clone , |
Silver Member Username: Lroy
Post Number: 195 Registered: Aug-06
Posted on It should be much easier if you just flash the box with the 292t bin. This bin is autoroll and that will take car of you keys issue.....Try it out.. |
Post Number: 68 Registered: Jun-06
Posted on i know , but when it go down , thats when i need it for |
Bronze Member Username: Viruscauser
Leesburg,
Georgia
Post Number: 17 Registered: Mar-07
Posted on Menu Parental control enter second pin (0000) Click ok on Nagravision2 That's where the Keys go. |
Post Number: 69 Registered: Jun-06
Posted on thanks now i hAVE 1 MORE PROBLEM, ALL MY CHANNEL MIX UP HOW DO ARRANGE THE BY # STARTING FROM 1........... |
Gold Member Username: Lklives
Post Number: 8179 Registered: Jan-06
Posted on Sort by sid or use the Dishnet or Bev package.. |
Post Number: 70 Registered: Jun-06
Posted on where do i find sort by sid on the vortex....thanks |
Post Number: 8185 Registered: Jan-06
Posted on using your remote and menu |
