Rebooting?
Username: Vic123
TorontoCanada
Post Number: 20
hello guys i was just wondering if u guys have any rebooting solution...My pansat 2500 reboots by itself after every 20 mins. Im using d latesr bin on my pansat 292
What should I do in order to stop rebooting
Cheers
VIC
Username: Brucester
Post Number: 367
buy a cw600p or viewsat or try older bin from pansat i got pansat in my other room and it is working good with the 292t my pansat is a lava3200 witch is clon of pansat and pansat is going to stop macking bins for that box you will have to spend money on a new box cw600p is going for 110 can and viewsat for around 200 is up to you get new box or play with that pancrap every 20 min is up to you have a nice day
Username: Viruscauser
Leesburg, Georgia
Post Number: 13
Pansat clone with 292T here and works fine. Try setting the autoroll and TP autoupdate off. That seems to have helped cure most of my reboot problems.
Username: Hardrockstriker
Post Number: 715
Vic, you have angered the satellite gods, hence the curse on your receiver...
Try doing a factory reset and reloading your bin.
Username: Angie_wedgewood
Post Number: 28
Probably a dumb question, but how do you do a factory reset?
Username: Lklives
Post Number: 8162
look in the menu...
Post Number: 30
Ha apparently it was a dumb question. My problem is this though... My CS did the weird flashing thing where the power goes out and then comes back on, and usually its fine and comes back right away, but this time when it tries to come back on it just keeps showing a "1" on the box in the display and keeps powering off and on. Any idea how to fix this? It's almost like its trying to find a channel but can't and keeps turning off...help?!
Username: Lklives
Post Number: 8163
factory reset in menu...upload factory bin...reset antenna/lnb settings ...new scan...upload latest bin...wait for autoroll keys...wait and let EPG populate...rear switch reboot....watch tv
or use older bin and manually enter keys
