Bronze Member Username: EnzohoPost Number: 18 Registered: Jan-07 | I have a dish install by bev 91and82 before.Now i didn"t used.Anyone can tech me how to change the angle receive Dishnet .I live in toronto.My dish size is 18"two-dish.can i receive 61.5,110 or 119? Please help.Thankyou. |
Silver Member Username: RtapMIAMI, FL MIAMI Post Number: 125 Registered: Jan-07 | Satellite Finders (Look Angle Calculators) ------------------------------------------------- [link removed] http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm I know your newbie at this but read the threads before you answer questions. I myself did this and learned. now go and learn |
Bronze Member Username: JoedPost Number: 19 Registered: Sep-06 | your current setting should be AZ 190 ELV 39 SKW 95.6 Your new setting are AZ 225.4 ELV 28.6 SKW 117 With out even looking at what your current setting lower the dish down by 10 degrees from its current setting. Tilt the skew 11 degrees from its current. Then start turning it slowly to the west until you hit the DN sat. If you are using an external switch I would bypass it and connect direct to one of the LNB. From the back the one on the right is 119. It will be the lower one also. |
Bronze Member Username: JoedPost Number: 20 Registered: Sep-06 | MISTAKE in previous post The 110 is the one on the right and lower from the back. |
Bronze Member Username: EnzohoPost Number: 19 Registered: Jan-07 | Thankyou for help Joe Devlin. |
