Stereo skipping
Username: Talon_es93
Trinidad, Co
Post Number: 593
why does my stereo skip every time i turn up it up.... could it be that i need a bigger alt.?? i had a thunder 81000D (2 ohm stable) pushing 2 CVRs 12" ... i had em hooked up @ 1 ohm so i thought thats probly why... but i switched the amp now i have my bro-in-laws A1500HCT @ 1 ohm and ever time i turn it up it still skips... or could it have been the it did it before b/c of the ohms and now it does it b/c of the subsonic filter???.... and it might just be me but i think it skips less with mp3s rather then with regular CDs.. thanks for any help/opinions given
Username: Nd4spd18
Southeast PA
Post Number: 811
Either your HU is going bad, or your amp gain is set too high.
Username: Adddisorder
West palm, Florida
Post Number: 3698
probly your voltage dropping so bad your HU shuts off
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 329
haha when i had a sony explode HU it would shut off when teh bass would hitt, then i got a new alpine hde-9856 HU and for some reason i dont have any probelms anymore but my lights till dim pretty bad when i had my amp working but my amp is blown now witch sux , ill be getting all new stuff soon, ohh yea sry for cuuting in this forum but i had the same problem when i had my system in and i now have no system only subs with no power lol, and no problems now that i have a new Hu and no system
West palm, Florida
Post Number: 3701
michael, sounds like the alpine can run off a lower voltage, and your amp blew because it wasnt getting enough current
Username: Extrmndor3
IF U HEAR ME... I GOT KING K...
Post Number: 4083
yes..... the alpine has beefire caps... that can help at lower voltages..
the caps wills torage energy and when the voltage really drops it gives th eenergy needed it but sometimes its too much voltage drop that the caps wont help....
alot ofpeople says a small cap on the battery helps alot but its dangerous..... all of the heat the cap can explode.. like near the headunit u can wire a .5 farad cap and will help alot on the sq ( no clippin from the h/u)
Trinidad, Co
Post Number: 594
maybe .. i have the amp 3/4 of the way up and my hu is a panasonic cq-c7301u
Trinidad, Co
Post Number: 595
i checked again and it skips like if the cd was scratched and when it plays mp3s it just all shuts off... well every thing stays on but its like if i hit a big pot hole or something
Username: Johnfiac
IL Afghanistan,...
Post Number: 1792
i had the problem with a cd player doing that... the cd player was bad... no voltage problems or anything, i could even disconnect the subs and have the amp off with the hu up and it would skip. I thought i had to much bass and not a tight enough mount to the dash... but bad HU... is it a Kendwood?
Trinidad, Co
Post Number: 596
no its a panasonic... if i turn the sub vol. off it won't do it no more.. imma try to turn the amp only half way up see what happens... but can it also be that i have my stock speakers still straight to the stereo???think it would change alot if i was to put my 4 channel on my stocks?
Username: Jlaudiow7
Indianapolis, Indiana United states
ur either have a bad head unit or it not mp3 format all song have to be mp3 not just some all i had tht problem
