Archive through February 27, 2007
Username: Lklives
Post Number: 7908
Nagra2 Keys...For All Receivers!
Dish Provider 0101: Last Updated (Feb 21 4:30pm EST)
Key 0: 3D 21 B6 E9 C2 2D 99 B4 D7 CC 39 1C BC C5 87 CD
Key 1: A7 3D 65 27 D1 55 53 10 7B 40 7C 49 F9 E4 AA DD (Active)
Bev Provider 0901: Last Updated (Feb 20 8:0pm EST)
Key 0: 8A E9 FE 60 C3 7C DC 79 09 1A 7F 26 5F E2 9E AE (Active)
Key 1: 08 23 27 04 D1 B3 71 6B 3D 6C 60 5D A4 79 D5 04
Username: Ismailbawa
Post Number: 15
thank you very much LK
Username: Waiting4zion
LK- what is meant by (Active)?
Username: Lklives
Post Number: 7910
Active means basically to the user, such as yourself, that its the latest key that was changed..its the MOST recent key that was changed/active...I could give U a bunch of technical jargon but for all intents and purposes, active is just as I stated for U..
thank you, I am trying to understand this stuff.
I have an 2000 Ultra and am learning from this site.
Username: Lklives
Post Number: 7913
I HIGHLY suggest U learn from www.totalfta.com which is the OFFICIAL Dss satellite site for all Viewsat receivers such as your Ultra!
Username: Canndy
Www.livefta.com, Www.livefta.com Www.livefta.com
Post Number: 346
[link removed]
Username: Bertoro
Toronto, Ontario Canada
Post Number: 497
Key 0: 2A 81 C7 8E 39 7F 7F 09 AA 5B 02 53 D0 EA 7F 7B (Active)
Username: Asharfi
Post Number: 612
dishnetwork keys
00: 2A 81 C7 8E 39 7F 7F 09 AA 5B 02 53 D0 EA 7F 7B (Active)
01: A7 3D 65 27 D1 55 53 10 7B 40 7C 49 F9 E4 AA DD
feb.21.2007 (9:48PM)
Username: Hicham
Post Number: 61
bev 21 feb 21h48
00: 8A E9 FE 60 C3 7C DC 79 09 1A 7F 26 5F E2 9E AE
01: 08 23 27 04 D1 B3 71 6B 3D 6C 60 5D A4 79 D5 04
Username: K98
Post Number: 22
good work AV keep it up
Username: Asharfi
Post Number: 613
Thanks!
Username: Sirroy
Edmonton, Alberta Canada
Post Number: 10
Latest Bev keys Active Feb 21
Username: Asharfi
Post Number: 614
bellexpressvu keys
86: 8A E9 FE 60 C3 7C DC 79 09 1A 7F 26 5F E2 9E AE
96: DA 91 81 7E 6A F2 11 67 EC FE AB 96 FD 3F 42 4F (Active)
feb.21.2007
c/p from dssworld
Username: Sirroy
Post Number: 11
Thaks AV
Username: Asharfi
Post Number: 617
You're Welcome!
Username: Oglejust
You aint bangin unless..., Il
Post Number: 1103
i need the very top set of #'s for a viewsat extreme... like the 00 1 i think... i deleted it. and can i get the keys 2?
Username: Oglejust
Post Number: 1104
ok nvm i got it... i was 1 # off thats y it wouldnt work.
Username: Jpz
MTL, QC CAnada
Post Number: 170
hi guys
Username: To_munda
GTA, Ont
Post Number: 15
Great job guys. The DN keys are a workin !!!
Username: Yashmatharu
Brampton, Ont Canada
Post Number: 42
hi folks,
I have pansat 2500 clone and working on 289T. There is no signal quality this morning. Is it because of 289T or something else?
Username: Maxb43
if u have been using your pansat 2500a to watch dish network what adjustments do u have to make to watch bev and can your satilite stay in the same posistion
Username: Nasaboyusa
Does anyone know how i can get back some of the t-5 channels that were lost a month or so ago, like TVRI, PROTV ...and others
Username: Halat
HARRISONBURG, VA
its time to updat
if you C go way in 3 days
you need to
Username: Nydas
Post Number: 1977
If your receiver was working well and has stopped suddenly, make sure it has the lkatest kesy, and try to reset it by turning the switch off at the back and on again
Username: Angie_wedgewood
Post Number: 18
Does anyone have the keys for today please? My keyripper program isn't updated since yesterday.. Thanks
Username: Eechag
Montreal, Quebec Canada
Post Number: 42
Bev and DN are down, new keys please.
thank you
Post Number: 19
Bev Keys for Feb 22/2007
key0: 523F5B6C17813DA8781D9672DA0220AC
Key1: DA91817E6AF21167ECFEAB96FD3F424F
Username: Cooldude69
Post Number: 105
D!SH Last Update: 02/21/07 07:14 pm
00: 2A81C78E397F7F09AA5B0253D0EA7F7B
01: A73D6527D15553107B407C49F9E4AADD
B3V Last Update: 02/22/07 04:39 pm
00: 523F5B6C17813DA8781D9672DA0220AC
01: DA91817E6AF21167ECFEAB96FD3F424F
Username: Canndy
Post Number: 347
[link removed]
Username: Modi
What should be the provider ID?
Nagravision 2
pansat 3000(2500 clone)
any one can answer??
Username: Jowhar
Post Number: 84
Username: Nydas
Post Number: 1986
Nagravision 1: Obsolete.
Nagravision 2: Current
.........DN:......Provider ID = 0101
........BEV:.....Provider ID = 0901
Globecast:.....Provider ID = C101
Special BEV:...Provider ID = 0905
Special BEV:...Provider ID = 0906
Username: Nydas
Post Number: 1988
Nagravision 2 Keys
DN: Provider ID 0101 (Last Update: 21st Feb., 2007)
Key 00 (86):
Key 01 (96):
BEV: Provider ID 0901 (Last Update: 22nd Feb., 2007 17:34)
Key 00 (86):
52 3F 5B 6C 17 81 3D A8
78 1D 96 72 DA 02 20 AC
Key 01 (96):
Special for BEV 0905 and 0906
BEV: Provider ID 0905 (Last Update: 2nd Feb., 2007)
Key 00 (86):
76 9E 38 43 12 8D 8B 95 46 C8 16 F0 83 28 E5 AC
Key 01 (96):
C9 57 64 42 94 E1 33 98 F9 90 68 6B 34 3C 95 B2
BEV: Provider ID 0906 (Last Update: 27th Jan., 2007)
Key 00 (86):
F7 59 26 70 29 6A DD B7 00 69 BB 31 3E 41 33 1C
Key 01 (96):
EE 23 A4 46 C5 36 6A 22 20 63 AB 89 0E E7 5A 56
Username: Jpz
MTL, QC CAnada
Post Number: 171
hi Nalin, please can you tell me what is the difference between Special BEV and BEV??
thank you an advance.
Username: Mkvl1490
Post Number: 95
i put the new keys in and i keep getting waitng for pic and it will go all day way up 1000000000000%
Username: Vijayveena
Makaveli:
Try switching it off and then on. It worked for me.
Username: Mkvl1490
Post Number: 96
i did that too, still nothin happened. i got 2500, 286 bin. the percentage keep goin up and no channels
Username: Nydas
Post Number: 1990
JPZ: Normal Provider ID for BEV is 0901. However, in January and early February, BEV used ID 0905 and 0906 for special events and certain PPVs. This was reported in some forums and there are different keys for that.
In Pansat 2500 and 2700 clone software (and in many other receivers) you can add extra IDs.
Menu/Prental control/second Pin/0000
Autoroll off - Nagravision 2/Provider Id.
Right scroll thtough 0101, 0901, C101 and when you see FFFF, manually enter 0905 or 0906 as appropriate and enter the respective Key 00 and Key 01 for each.
So that people do not get confused, I have used the word "special" for these two IDs.
By the way, there is a Globcast (ID C101) breakthrough expected soon.
Username: Atinsd
Hi,
I am new at this. Does anyone know how I can get these channels back:
ART, NILE, FUTUR? I lost them in January.
I have SatCruiser 101+
thank you so much
Username: Nydas
Post Number: 1992
Makaveli : I am presuming it was working OK before. Do the following:-
1. Correct date/time and time zone.
2. Autoroll off.
3. Switch off at the back of receiver, wait 40 seconds and turn it on.
4. If not successful, do "Set default Keys"
5. Enter appropriate Nagravions 2 keys - both Key 00 and Key 01. The do item 3 again.
6. If not successful, try BIN 289T
7. If you do not want International channels, do item 1 above, and install BIN 290T, keep autoroll on. Also do Item 3 after install.
If keys do not roll in, try manual key entry with autoroll off.
Username: Eatfish111
Post Number: 170
Makaveli just turn the autoroll off then enter keys, thats all you have to do it will work.
Username: Army
please i need keys for pansat 2500 thank you
Username: Nydas
Post Number: 1996
jose: The keys have not changed since I last posted them above - Look about 7 posts above yours. Keys are the same for ALL receivers. I have given further instructions 3 posts above. After you have done all that, and you are still not seeing TV, then post the details of your BIN (Menu/system info) for further help.
Username: Sirroy
Post Number: 12
Does anyone have Bev keys for today's date 23rd
Please and thank you.
Username: Gastrognome
Post Number: 23
[link removed]
Username: Pu_da_munda
Hi Guys,
I am using pansat 2500a with BIN 288T. From last so many days I am not able to view some of the Indian channels like Z , Cine, MAX, Sony, B4U etc.
Can anyone tell me what to do for getting these channels.
Username: Lklives
Post Number: 7980
I believe that has been asked 100 times and answered here 100 times in the past 3 days..READING is a wonderful thing..
Username: Todorica
Atlanta, GA USA
hi guys, does anybody got the latest DN keys please?
LK: I am new user and moreover after reading all the messages in the list i have posted my problem bcoz i didnt find any solution in the list since 17th FEB.
So please if you dont mind can u tell me the solution for the problem.
Username: Dude123
Post Number: 943
Sidhu Preet
Here is Nalin Nydas experience regarding those channels:
Unfortunately just those important Indain channels do not come through nicely with this autoroll BIN. Missing would be
ZEETV, ZCINE, SET, SETMX, B4U, SPORTS
I had to change back to 289T. It does NOT have autoroll, so when the keys change you will have to manually update. There were a lot of freezes and system resets before, but by keeping the autoroll and auto update off, I have had very few glitches, except for having to manually enter keys.
When you try to upload 289T, you might have difficulties. I got round it by first uploading 280T and then 289T.
Username: Todorica
Atlanta, GA USA
Post Number: 7
new Dish keys please..?
Post Number: 7
The One :
Thanks for information and a solution.
One more thing, in my computer i dont have serial port as it doesnt come with new computers. How can i load 289T bin in my receiver.
Username: Nydas
Post Number: 2011
Sidhu Preet : Read in this thread about USB to serial .
https://www.ecoustics.com/electronics/forum/home-video/324546.html
Read in this thread about 289T and 290T BIN.
https://www.ecoustics.com/electronics/forum/home-video/326678.html
Spend a bit of time reading it all then decide what action to take.
Username: Dude123
Post Number: 944
xxx
Here are the latest ones for both
Nagra2 Keys
Dish Provider 0101: Last Updated (Feb 21 9:30pm EST)
Bev Provider 0901: Last Updated (Feb 22 9:30pm EST)
Key 0: 52 3F 5B 6C 17 81 3D A8 78 1D 96 72 DA 02 20 AC
Key 1: 07 47 1F 3C 39 D0 2A 44 DE 9A 9F 85 06 CB 3B 1E (Active)
Username: Illspamu
got keys?
Username: Illspamu
is there a reasion why the clock in my pansat 3500 keeps going allovertheplace?
its a real drag to keep having to set the clock right to be able to see the EPG
thanks}
Username: Nydas
Post Number: 2047
C00LSAT 8000 new BIN 111 is out.
https://www.ecoustics.com/electronics/forum/home-video/329335.html
Username: Canndy
Post Number: 348
[link removed] <KEYS
Username: Samson
How do I put keys in Pansat 3500SD?
Username: Lklives
Post Number: 8031
same as any other pansat...which is posted at every DSS satellite site on the internet..
Username: Mkvl1490
Post Number: 99
yo nalin its not just me, seems as tho a couple people is havin trouble outta of 2500. tha channels arent comin in like they should. to me it seems as tho people havin the wrong keys or sumthin. it keep sayin waiting for pic. and the quality and level is extremely high
Username: Nydas
Post Number: 2053
Makaveli: All I can suggest is that you start afresh with 280T or factory BIN, then load 289T and do autoroll and autotp off, set default keys. If you are happy to rescan, do a factory reset, and make sure you get all the parameter put in including time/date and zone.
Then enter the keys and save and switch off and on. I think you know the drill, but possibly you were hasty somewhere.
Username: Nestea
Post Number: 64
bev down. Please help with keys.
Username: Destine0429
Quebec Canada
Post Number: 161
BEV
Provider ID 09 01
Key Number 00
11 82 71 68 BD D8 C2 B1
A0 45 51 36 0D 8B 94 8A
Username: Nydas
Post Number: 2056
BEV Provider ID 0901 (Last Update: 2007/02/24 10:39 PM )
Key 00 (86):
Key 01 (96):
Username: Wwolf
Chatham, On. Canada
Post Number: 53
Username: Bolides
Wolvega, Frieslnd Holland
what are the keys for B4U, zeetv etc (Indian movie channels) ?
thx
Bolides
Username: Modi
Post Number: 7
Guys,
I am not getting many Indian Channels
Pansat 3000 (2500 clone)
Bin File: 290
Any thing i can do to make changes
Thankx
Username: Eechag
Post Number: 43
bev is down, please new key
Username: Wingate
Toronto, On Canada
god morning........? bev its down ........
Username: Crazy_greek
Post Number: 712
Hey Chang
You will find the Updated Keys for Bev
HERE.......www.filez.us/km3/keys.shtml
Username: Outtrend
Post Number: 28
Bev Provider 0901: Last Updated (Feb 24 11:00pm EST)
Key 0: 11 82 71 68 BD D8 C2 B1 A0 45 51 36 0D 8B 94 8A (Active)
Username: Girls_respect
DN is down, anyone have new keys?? Thnx in advance
Username: Zuhere79
DN is down from yesterday still looking for keys any help ??
Username: Asharfi
Post Number: 619
It's NOT down. I had the same problem. Turn OFF your receiver from the back and turn it back ON. And make sure your keys are correct.
Username: Hoosier_daddy
Post Number: 56
Working fine here....
Username: Asharfi
Post Number: 621
Here's a file for all Fortec STAR receivers that gives the download instructions. It's from Fortec STAR's website and the credit goes to them. This file will show you how to download bins properly, etc. It's in PDF format, which means you need Acrobat Reader to view this file.
Download: http://www.megaupload.com/?d=OTYHMTFH
Username: Zuhere79
thank you to AV AND LARRY BIRD I did reset it and it is fine now
Username: Bruce_munn
new keys for pansat 2500.
Username: Jpz
MTL, QC CAnada
Post Number: 172
hi guys
Username: Raghu
Post Number: 33
Which receiver is good for getting HD quality (HD CHannels) from DN?
I currently have 2700a.
Thanks
Raghu.
Username: Manthedent
Post Number: 16
hi
can u guys tell me if there is a way to get the rest of the arabic chanels on my pansat 2300?
Username: Palikeroako
Post Number: 38
someone help please... I put the codes in, but my BoX aint working... I tried turning the box on and off from the back and nothing... Please someone help...... THanx!!!!!
Username: Atul_shah
Post Number: 13
For quite sometime can someone tell why American Channels are not coming like ABC, NBC CNN PBS and many more..Only international Channels do come like some Indian, Korean, Arabic and Japanese.}
Username: Khawaja105
Post Number: 7
hi folks! I have a Bell expressvu 4100 receiver and Sony DVD Recorder. I am trying to record programs when i am sleeping by creating events. I schedule recording from bell receiver and DVD Recorder. Bell Receiver turns on by itself but DVD won't. Please either reply, or give me a forum name when I can go and ask this question. Thanks.
bev. is down please new keys for panset 2500
Post Number: 39
new keys please....
Post Number: 40
New keys for d.n. please........
Username: Larry1
Dawson creek, Bc Canada
Post Number: 21
any new keys for bev thanks
Quebec Canada
Post Number: 168
The keys have not changed.
Here are the last ones.
DISH
Provider ID 01 01
Key Number 00
Key Number 01
BEV
Provider ID 09 01
Key number 00
Key Number 01
Username: Outtrend
Post Number: 29
Bev Provider 0901: Last Updated (Feb 26 5:00pm EST)
Key 1: C5 3E 7C 37 FB 3A 86 16 70 B6 59 8C 91 03 EE 7E (Active)
Username: Outtrend
Post Number: 30
larry there they are, they just changed 40 min's a go
Username: Atul_shah
Post Number: 14
Hi Folks,
I have ACE 2700 not able to get American Channels. Need Help! is there a special scan or settings need to be configured???
Username: Dude123
Post Number: 948
Are you getting anything at all? what bin are you using?
Username: Atul_shah
Post Number: 17
The One,
Thanks for asking !!
I don't know much on this but, I am getting few international Channels. But, i am looking for CNN, Cartoon and other local Channels. What Bin am i using? I have no idea. Can you tell me how to find out?
Username: Dure
Mississauga, Ontario Canada
Post Number: 47
Iam new to Skyview RX600. Some body pl help. How do you input Keys manually on this receiver. There is no 'SIG' & 'B'(i) on the remote.
Username: Mksat
Hello To All,
I am using a CS8000. I was trying to configure a channel list. It was recommended that I delete old channels and rescan. Once I did, I have never recovered all the channels that I had. What am I doing wrong? I am new to all of this. Thank you!
Username: Dude123
Post Number: 949
Atul
go under your menu and then system info. and list whatever you see there
Username: Mksat
Model ID 4600C146
H/W 1.00.00
S/W 11.14.3F
