okay i had a hard time doing this..when i put the walls up and glue them...do i have to wait for the glue to dry and then..flip it over and drill the pieces into place? because the walls kept falling everytime i moved the box..i guess the glue wasnt dry..will it hold?
i ussualy glue as i screw.. make sure u predrill all the holes, screw your screws in so the boards are holding togethor but with a gap between em, put your glue in then tighten it down
that is why you use a clamp. if no clamp is available, then have someone help you.
or you can stand it on its side. predrill the hole and put the screw in there about half way. then apply glue and hold it up to the part where it needs to be placed. then use your other hand to drill the screw in.
Also before you start be sure to measure the spaces between the screws so the spaces look even! It looks sooo lame when a person shows off there box and they have a variance of spaces between each screw ( not mentioning names) Polo..
