How to get packages channel in 61.5W sat?????
Username: Newmen
Montral, Quebec Canada
Post Number: 20
how can i get the packages channel, in 61.5W. i have 289T instaled and when i scan the sat i don't have the packages channel!!!! please help
Username: Viruscauser
Leesburg, Georgia
Post Number: 8
Are you sure your dish is pointed correctly and do you have signal strength?
A scan of Echo 3 (61.5) on DiSEqC #3 should pick up all the channels.
Username: Newmen
Post Number: 22
yes i have all canandian and american channel like TSN FOXSP SNET1 2 3 4 CBC but i don't have channel like Zee channel and Indus Musique
Leesburg, Georgia
Post Number: 9
I don't know about C*nadi*n channels on 61.5 but check out the International (ZeeTV etc on D1sh Networks) that you should pick up on Echo 3 (61.5) at the link below.
Are you sure you are using the right DiSEqC settings (#3)?
If you are trying to scan the C*nadi*n sats, for Zee, I hope someone who knows that sat jumps in to help.
Good luck.
Username: Newmen
Post Number: 25
thanks Abby
Leesburg, Georgia
Post Number: 10
Oh yeah, the link: http://ekb.dbstalk.com/dishlist.htm
Username: Nydas
Post Number: 2088
289T should give all Indo-Pakistani Channels on Echor 3 (61.5W). Do not try 290T as you will miss some. To correct the situation, do a Blind scan, then turn off at back of receiver and turn it on again after 40 seconds. Sometime there are glitches, and you may have to wait a little changing channels, or try waiting somewhere nice in 110W or 119W.
2-3 times, in spite of doing a blind scan I had to do a specific TP scan. I do not have the TP list on me right now. The particularly evasive ones are ZEETV and MUSIK
Username: Prfrmnj
Post Number: 2222
This would be following you around! But I have nor the time or desire....
Username: Nydas
Post Number: 2096
Some of the TPs for Indo-Pakistani channels on 61.5W - Echo 3.
B4U, ZEETV AND ZCINE 12603 (V)
TVASA SET AND SETMX 12470 (H)
SPORT 12324 (H) for cricket.
MUSIK 12611 (V)
INDMU 12442 (H)
GEOTV 12630 (V)
BRIDGS 12427 (V)
Username: Newmen
Post Number: 27
i have X-85BL_070125_289T_db_api(N) instaled, i have all american channels, i do the bland scan and i turn it off and on after 40 seconds but i don't have Indo-Pakistani channels. please can you tell me what i need to do step by step and how can i do a specific TP scan???!!!
Username: Newmen
Post Number: 28
for example when i scan 12603(V) i got only: CTS and TELAT channel and i don't got ZEETV or B4U, please help
Username: Newmen
Post Number: 32
please help
Username: Crazy_greek
Post Number: 749
Hey NEWmen
At EchoStar 3 @ 61.5W, only do a TP Scan on these TPs. You will find the channels you are looking for.
(TP6) Freq.12297 (Pol.H) SR 20,000.
(TP12) Freq.12384 (Pol.H) SR 20,000.
(TP18) Freq.12472 (Pol.H) SR 20,000.
Username: Newmen
Post Number: 33
When i scan TP6 i got these channels only:
Vu-F
VuBuy
RAPTR
VuPPV
CRKT
CRKT1
CRKT2
CRKT*
NGRA4
NHLMH
But i don't know why i don't got
ZeeTV
Zee Cinema
ATV
B4U Movies
may be the probleme is the LNB, because i have Dish and LNB intaled by Bell expressVU and they use Bell ExpressVu Dual Output LNB!!!!!??
Username: Newmen
Post Number: 34
may be my Fortec Star Lifetime Ultra whith X-85BL_070125_289T_db_api(N)is not good and i need to change it???
Username: Nydas
Post Number: 2119
NEWmen: The 292T BIN is out. Use it instead of 289T or 290T
You will have to unzip and extract the serial version zipped file and then extract the BIN form it.
X-85BL_070304_292T_api and Full Jtag file
Moded for Hughes / Tivo ir codes. Good for ALL !
Special Thanks to JVVH for the help on this one.
[link removed]
Username: Newmen
Post Number: 35
thank you Nalin Nyda
