New member Username: ToxiccivicFlorissant, Missouri Post Number: 2 Registered: Feb-07 | So i just bought a monster of a sub and am intimidated at the thought of building my own enclosure. The manual talks about really specific tuning specs and port size and I'm wondering if I can just say screw it and throw the sub in some box I buy online and it will be all good. I dont plan on goin to competitions so I dont really care about getting the most out of the sub. I just dont want distortion. Check this bad boy out... cerwin vega stroker 2000 watt RMS ![]() |
Silver Member Username: Nickb4247Post Number: 250 Registered: Dec-06 | TCAB - www.thecaraudiobox.com | |
Gold Member Username: CtmikeCt. Post Number: 3496 Registered: Feb-06 | prefab boxes really suck. even if not trying to win comps a prefab is still not the way to go. i'd say go to a car audio store and have them make one for you if you can't make it yourself, or there's people here that could make one for you at a good price. | |
Gold Member Username: CtmikeCt. Post Number: 3497 Registered: Feb-06 | was just going to post the same link nick gave you and this one: www.woodlawncabinetry.com only boxes "online" i'd buy. |
Silver Member Username: Nickb4247Post Number: 251 Registered: Dec-06 | For a tighter budget, look at Imortal Box Building - logan116600@hotmail.com Email him with the specs of the box you need. |
Silver Member Username: OlegSanta Monica, CA USA Post Number: 519 Registered: Nov-04 | For sealed enclosures, all that needs to be correct is the volume - as in it needs to be within the manufacturer's spec? Is it then ok to buy a prefab sealed box if it's the right volume? | |
Gold Member Username: BlainewPost Number: 2200 Registered: Nov-05 | klausaudio.com | |
Silver Member Username: Nickb4247Post Number: 252 Registered: Dec-06 | If you find a prefab sealed enclosure with the right volume, it will sound fine. But, if it is cheap/poorly constructed, it will flex and resonate. With a stroker, I would want a rather sturdy box. | |
Silver Member Username: KravenbloodOhio DD Z1 you wi... Post Number: 217 Registered: Aug-05 | they got updated specs too i dont know when yours was packaged but heres the new specs
