? bout my BL box design...
Username: Tremor1127
Fi Car Audio [:-]
Post Number: 1110
this is my design for two 18" BLs...
they seem like im pushing them a little hard sometimes and they are only getting maybe 1000 watts apiece. i think i need a bigger box. im not sure though.
what do you guys think?
Fi Car Audio [:-]
Post Number: 1112
forgot pic...
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3921
i posted in your other thread so read that.... but i just wanted to tell you this as well... when i had my ava installed... i had a jl1000/1 hooked up to it with gain VERY minimal. i mean it was prolly seeing lke 300w rms but was acting like you describe. i checked the amp and it was fine too... i was very confused. i ended up finding out my HU sub preout was cacked. i'm not suggesting this to be the problem but its probably not the subs or box. my guess is the amp since you were saying bass boost was full. if not the amp then maybe check the HU?
Fi Car Audio [:-]
Post Number: 1133
this thread dissapeared after i put the pic so i made another thread...
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 295
hey tremor where do u go when you go to that website to do the box building lik how u did and got a pic?
Post Number: 3942
he paid for that design michael. TTB no longer does designing though. you can have a box built and shipped out to you though. www.teamtoxicbass.com click the enclosure engineering picture.
Username: Mike_16
Post Number: 296
ok wha then after you click encloser engineering pic? trevor
Username: 54danny54
KY More Wang Th...
Post Number: 3627
after u click engineering..
click>products>request a quote>fill out all the info
Username: Lil_j
CantonUS
Post Number: 10
hey (tremor1127) that port is to BIG it's to long
what is the net box volum? 5cu.ft???
Post Number: 3950
you dont understand its not a bass reflex enclosure. i can assure you that you cant calculate how that box works... I've been studying them for a while now and am still very confused.
Username: 54danny54
KY More Wang Th...
Post Number: 3630
yea it looks more like a T-line due to the port length and size.
maybe its there T-box they have?
i know ttb wouldnt screw that up.
Username: 54danny54
KY More Wang Th...
Post Number: 3631
i know ttb wouldnt screw that up, just dont seem right that they would.
Post Number: 3951
yes it is a t-box.
