Painting a box?
Username: Nd4spd18
Southeast PA
Post Number: 731
Has anyone on here painted their box instead of carpeting it? Pics?
What type of paint do you use? Anything else I should be aware of when doing this?
I am thinking about painting my box gray, since my truck's interior is gray. The reason for all the questions is because I haven't painted anything before.
Username: Naledge503
Qnited States of FI Ca...
Post Number: 1034
Before...
no port paint..ewwwwwwww.
After.
I dont remember what paint I used. I think it was Black semi-gloss. It was something I had just laying around in the garage. Not sure of the brand.
A pic is worth 1000 words
Post Number: 4219
Remember to fill in dem holes.
Username: Nd4spd18
Southeast PA
Post Number: 733
Was that spray paint Jesse?
Username: Johnfiac
IL Afghanistan,...
Post Number: 1691
i painted my ports and carpeted my box.... it looks nice
Post Number: 1036
No it wasnt spray paint. It was a mess doing the port. I dont have a paint gun or anything so I had to put my whole arm in. Used a roller for the most part then, to get all the little areas I used a brush.
Username: Rovin
1 12 Atomic ...
Post Number: 10860
looking good Jesse - but like paul said ......
Post Number: 1040
haha, yeah. BM3 made the box, I just painted it. I dont use that box anymore though. I sold the cvx's.
Username: Nd4spd18
Southeast PA
Post Number: 742
Hmmmm, so what do you guys thinks I should use: spray paint or a roller?
Post Number: 1044
imo, spray painting would be alot easier.
Username: The_image_dynamic
San Diego
Post Number: 472
roll-on or spray-on bed liner is the way to go IMO
Username: J_baby15
Kentucky
Post Number: 1304
J Designs has a thread bout how to do it..
check the site in the enclosure section...its a good tutorial
Username: Nd4spd18
Southeast PA
Post Number: 748
Link? I looked and didn't see it.
Username: Nd4spd18
Southeast PA
Post Number: 759
Username: Van_man
Boston South, MA
Post Number: 2149
What kind of finish are you going for?
For a smooth shiny finish, use primer on the box first. let dry completly, sand, then apply 2-3 coats of finish, sanding inbetween coats. Bondo all screw heads first.
For a glass like finnish. Apply resen on the box, and sand betwen 4-5 coats. Prime, wet sand fill voids, prime wet sand, finish with 2-3 coats of spaypaint, wet sanding inbetween.
