Bronze Member Username: Danoh
Post Number: 74 Registered: Nov-06
Posted on i flashed my reciever with this bin and 4 an hour now it says autoroll processing.anybody have any ideas.viewsat plat.b3v |
New member Username: Jamesb
Post Number: 4 Registered: Mar-07
Posted on 1st make sure autoroll is on.... 2nd go to the code menu in nagra and make sure your lines are proper 0901 08 09 88 89 3rd turn the box on and off from the back 4th leave it to autoroll (about 5-6mins) 5th if all else fails...reflash....make sure you loaded the correct bin |
Post Number: 75 Registered: Nov-06
Posted on ive tried everything above and still no tv.any other ideas. |
Bronze Member Username: Jamesb
Post Number: 13 Registered: Mar-07
Posted on ok what box do you have...give me some info and i can help.... |
