070304 bin
Username: Danoh
Post Number: 74
i flashed my reciever with this bin and 4 an hour now it says autoroll processing.anybody have any ideas.viewsat plat.b3v
Username: Jamesb
1st make sure autoroll is on....
2nd go to the code menu in nagra and make sure your lines are proper
0901
08
09
88
89
3rd turn the box on and off from the back
4th leave it to autoroll (about 5-6mins)
5th if all else fails...reflash....make sure you loaded the correct bin
Username: Danoh
Post Number: 75
ive tried everything above and still no tv.any other ideas.
Username: Jamesb
Post Number: 13
ok what box do you have...give me some info and i can help....
