Hello while trying to update the keys on my Sonicview Bellexpressvu 82 91, I also mistakenly did some scan channels etc. Omg now im having same channel list twice on my EPG as well as menu and everywhere. Like 212, 212, 213, 213 etc..
its a problem with your port settings....make sure each switch is on the right satellite and do a rescan of all the channels...it might be scanning it wrong...what kind of switch do you have? if its not a diseqc switch u might have to change some settings
What jamezb is saying is that in your receiver antenna setup you might have (and I'm just picking a port number arbitrarily) Nimiq1 on port 1 and Nimiq2 on port 1 as well. You must not have two different sats on the same port.
Ok now im able to get some channels correctly. My nimiq 2 is on port 1 and I scanned all the channels it appears to be working fine. Now im trying to scan my Nimiq 1.3 on port 2 and everytime I scan the channels it gets stuck on 12percent (4/32) and never increases more then that. Shows venus channel on tv category and radio is empty.
sometimes it happens to freeze....try one more time....if not just scan one at a time by unplugging....i have never met anyone who has had a problem doing it this way....sometimes there is glitches using other medthods
it does not work i tried deleting channels, but it wont delete some channels and freezes up on nimiq 1,3. I cant even scan channels on nimiq 1,3 since it will get stuck on 12%. Would I need to do a factory reset? I never did that before im really scared? Where can I get a latest bin for sonicview 1000?
do it....it will not do anything...all it does is reset all the settings....before u do it try one more thing......
go to the antenna settings and make sure that only port 1 and por 2 are on the nimiq sats if for instance koreasat 2 has one open it will affect your scanning turn all the other sats to none for port settings
