Signal 75% but no Quality-bev 91
Username: Sgt_cobra
New York, N.Y. Kings
Post Number: 7
cannot get a quality but getting a 75% on signal, please help.i believe i have the newest keys changed them and same problem. Do I have to also change the keys in bev08 01 when i change them in 09 01????
Username: Lklives
Post Number: 7954
If U ask that question about keys and Bev and DN providers, then u have no idea what u are doing...so I suggest U go read cause your quality level could be related to many different things..
Username: Nydas
Post Number: 1997
Mr Marcus: You can ignore 0801, which is old Nagra 1. Use only 0901.
Do a manual switch off of the receiver with the back switch and turn it on after 40 seconds. If this does not work, enter the keys again AFTER doing set autoroll off and set default keys.
Username: Lklives
Post Number: 7963
0801 is NOT old Nagra 1...its Bev Canadian satellite TV Nagra 2 on most receivers...
Username: Nydas
Post Number: 1999
Canadians using FTAs are only entering 0901 keys as posted everywhere.
Username: Lklives
Post Number: 7966
I stand corrected ...0901 is Bev nagra 2..the poster needs to provide more info as to his receiver type,,cause 0801 is still used by some..
Username: Rcfiddlerman
Post Number: 27
it sounds like youre pointing at a signal with the wrong transponder on (ie: nimiq 1.3ku with bev)that would be right but echo 9 with bev wouldnt, hope this might be it and hope this helps
Username: Ben333
hi guys,
in my dg7000,for nimiq1 I got 70 on signal,
98 quality,but no channels, just the fta channel of Vu...i have the latest bin ,and entered the keys well...do you know what is wrong?...thanks
Username: Juancho
Superior Lake, Northwestern... Canada
Post Number: 713
Yes. you have to go bottom to save the keys. then exit.I have 2 of these receivers .Be sure that you save the keys one at 00 two at 01 then next gomto save key and exit.
Username: Juancho
Post Number: 714
Turn off autoroll, then write keys 00 and save it ( click ok) now go to next key 01 and save ( click ok) now go to the bottom save keys (click ok ) exit.
Username: Ben333
thanks juan ,but i did all that you said,every time and it doesn't works
Username: Jamesb
Post Number: 11
u are only getting free to air channels
u need to get scrambled ones too....something is wrong with your settings or the bin you have
