119 on Bell ExpressVu is it possible?
Username: Mrperfect2007
Hi Guys and girls.
I have a Sonicview 1000 with a Bellexpress vu dish for 82 and 91. Im really intrested in getting some more channels especially Indian and hence was recommended by people to get 119.
Im wondering if it is possible to do that with my existing satellite, or do I need to buy another satellite and go through all the pain of installing it. Even if I do how am I able to hook up those extra wires into my receiver?
Any help would be appreciated.....
Username: Tapeman
Post Number: 663
Actually
I do think Invacom SNF-031 can get that new Sat 118.75
But test at your risk
Not for a nubie
Try 61.5 or 148 they got few Indian as well
Username: Hardrockstriker
Post Number: 685
Unless you have a toroid dish you will need a second dish to get the dish network sats. I've also heard of people using those old Primestar (?) dishes to get both dish and bev - but that's a hack.
You can hook up the extra dish and lnbs thru a disecq 4-port switch.
Username: Tapeman
Post Number: 665
There is no international on 119
So I'm not sure what he is looking for
But you are right most likely 2 dishes
So that means I shouldnt go for 119?
By the way what is this 148 and 61.5? And can I have them both on a single satellite?
Username: Tapeman
Post Number: 666
If you are east cost go for 61.5
If you are west cost go for 148
61 and 148 same broadcast 2 different spot beams
Ok so how many LNB do I need to have on my dish? one or two? also does it needs to be some special dish or something like that?
I have a dish in my garage it says RCA and it has one LNB and lying in there is there anyway I can make use of it to get 148 since I live on vancouver west coast?
Username: Tapeman
Post Number: 667
Yes perfect mr perfect
Single small dish with one LNB seperate align for international
4 input DISEqC switch and simple setup in antenna you can get all 3 satellites
Make sure reciver off at all time when connect cables and switch
Username: Cntrlaltdel
Post Number: 122
My question is... why wouldn't you already have 110 & 119 instead of 82 & 91... especially 82?
The only thing on BEV I ever watch are TSN, Sportsnet & the p0rn... the rest is garbage!
Username: Nydas
Post Number: 2079
Mr. Perfect: You can only get 81/91W BEV or 110/119W DN with your dish.
There is a newer combination DN LNB which will get 110/118.8W. 118.8W has many International channels, but they are somewhat different from the more popular ones on 61.5 or 148W. You need a separate 18" dish to get one of these, and in Vancouver you will scan 148W.
With DN supplied (or BEV supplied) combination LNB, you may have difficulties with getting a proper signal through a DisEqC 4 to 1 switch, and you might be better off with separate LNBs for 82 and 91 W on one dish (or 110 and 119 W) and 148W on the other dish, feeding your receiver through a 4 to 1 DisEqC switch.
Hey Guys really apprecite your response. Thank you so much. Im also wondering if there is anyway I can install my dish without a compass? Because my previous dish is installed by Bell and I never had to install any dish in my life. Can you guys give me any tips and suggestions in installing a dish to 148? Also can anybody tell me if I need to do something in the receiver menu also after installation?
Username: Tapeman
Post Number: 668
I never use a compass
Here is a small tip:
- If your 82/91 LNBs pointing to 11:00 O'clock
- 110/119 LNBs will be 12:00 O'clock
- 61.5 will be about 9:00 O'clock
- 148 will be about 3:00 O'clock
Who would need a compass if you can do it that way.
It should be a lot of fun
Well I can try your suggestion for sure and hopefully it should work. Can you also tell me what exactly is Grounding and how do I do that? Is it really important? Also if I get the direction right then is it possible to view it right away or do I need to do something in the receiver menu settings also?
Username: Tapeman
Post Number: 669
Grounding is connecting a thick wire from metal case to ground.
It can save your piece of electronics equipement from lightning damage. I would recommended to any installation exposed to heavy rain.
If you are not using DISEqC do it on the F/F coax coupler
