I don't know about C*nadi*n channels on 61.5 but check out the International (ZeeTV etc on D1sh Networks) that you should pick up on Echo 3 (61.5) at the link below.
Are you sure you are using the right DiSEqC settings (#3)?
If you are trying to scan the C*nadi*n sats, for Zee, I hope someone who knows that sat jumps in to help.
289T should give all Indo-Pakistani Channels on Echor 3 (61.5W). Do not try 290T as you will miss some. To correct the situation, do a Blind scan, then turn off at back of receiver and turn it on again after 40 seconds. Sometime there are glitches, and you may have to wait a little changing channels, or try waiting somewhere nice in 110W or 119W. 2-3 times, in spite of doing a blind scan I had to do a specific TP scan. I do not have the TP list on me right now. The particularly evasive ones are ZEETV and MUSIK
Some of the TPs for Indo-Pakistani channels on 61.5W - Echo 3.
B4U, ZEETV AND ZCINE 12603 (V) TVASA SET AND SETMX 12470 (H) SPORT 12324 (H) for cricket. MUSIK 12611 (V) INDMU 12442 (H) GEOTV 12630 (V) BRIDGS 12427 (V)
i have X-85BL_070125_289T_db_api(N) instaled, i have all american channels, i do the bland scan and i turn it off and on after 40 seconds but i don't have Indo-Pakistani channels. please can you tell me what i need to do step by step and how can i do a specific TP scan???!!!
Hey NEWmen At EchoStar 3 @ 61.5W, only do a TP Scan on these TPs. You will find the channels you are looking for. (TP6) Freq.12297 (Pol.H) SR 20,000. (TP12) Freq.12384 (Pol.H) SR 20,000. (TP18) Freq.12472 (Pol.H) SR 20,000.
When i scan TP6 i got these channels only: Vu-F VuBuy RAPTR VuPPV CRKT CRKT1 CRKT2 CRKT* NGRA4 NHLMH But i don't know why i don't got ZeeTV Zee Cinema ATV B4U Movies may be the probleme is the LNB, because i have Dish and LNB intaled by Bell expressVU and they use Bell ExpressVu Dual Output LNB!!!!!??
NEWmen: The 292T BIN is out. Use it instead of 289T or 290T You will have to unzip and extract the serial version zipped file and then extract the BIN form it.
